GL1500: One Easy, One Harder Problem - Page 2 - Steve Saunders Goldwing Forums
 7Likes
post #11 of 14 (permalink) Old 12-17-2018, 09:55 AM
Pure Texas's Avatar
Make: Goldwing
Auto zone has a product RXP in a orange bottle that is the strongest product for Carbs that I have ever used,I think itís better than Seafoam, itís a small bottle but stout,it cleaned up my 1500 after setting for a while.
AZgl1800 and AJAugust like this.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #12 of 14 (permalink) Old 12-18-2018, 01:59 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Originally Posted by C8Chris View Post
...I know the 90 degree tube bends are most failure prone. Where are they? Do I have to remove the carbs to get at them?...
^This is THE notorious 90-deg vacuum hose that fails... It operates the Timing Advance. Easy fix, and you can use Stock tubing (rather than Honda Part) so long as you put a nice bend in it.
limpy45 likes this.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #13 of 14 (permalink) Old 12-20-2018, 07:05 PM
redwingrider3's Avatar
Year: 1975/1997/2016
Make: 3 goldwings
Model: gl1000/asp1500/1800
Gas millage 38 to 44 mpg on my 97 with 96,000 miles just depends on how far you twist the grip ! 55 to 60 mph works bout the best.
limpy45 likes this.
Steve
redwingrider3 is offline
post #14 of 14 (permalink) Old 12-21-2018, 11:11 AM
Year: 2008
Model: 2008 GL1800 Comfy
A big YES on this one!
AJAugust is offline
Easy way to change rear 1500 tire not so easy. Chromo Goldwing Technical Forum 24 09-30-2011 05:59 PM
GL1500 Harder to start after shutting down from a ride onevw Goldwing Technical Forum 4 05-27-2011 11:36 PM
THAT WAS HARDER THAN EXPECTED. Bike...and Dennis Goldwing Technical Forum 24 02-15-2010 06:42 AM
must of hit my head harder than I thought...... Cousin Jack General Motorcycle Discussion Forum 25 08-14-2008 06:11 PM
harder to change gears with amsoil? deputy steve Goldwing Technical Forum 16 05-09-2006 06:40 AM
