Cooling fan - is it an amps thing - Page 5 - Steve Saunders Goldwing Forums
 10Likes
post #41 of 42 (permalink) Old 01-15-2019, 06:08 PM
brownfoxx1's Avatar
Make: gl-1500
Model: Interstate with roadsmith trike HT1500 kit
fans hooked to toggle switch
i ran a ground wire from ground under seat, then to a 5 amp fuse, then to a on-off toggle switch, then to both ground wires on the fans. now when in traffic, i can reach into the pouch, and turn on both fans. just what i did.
brownfoxx1 is offline
post #42 of 42 (permalink) Old 01-15-2019, 06:53 PM
Why didn't you just replace the sensor? It would have not been much harder than doing that wiring and you wouldn't have to worry about forgetting.
How to calculate amps required for electrical clothing linheart General Motorcycle Discussion Forum 6 02-02-2008 01:27 PM
A question on Amps and watts eddy Goldwing Technical Forum 2 01-19-2008 05:30 PM
Can I buy 30 Amps fuse in car store? Or I have to go to a dealer? newbiker Goldwing Technical Forum 12 08-03-2007 09:33 AM
variable amps on my `86 gl1200I El^Diablo Goldwing Technical Forum 1 05-23-2007 09:24 AM
Sparking Amps ARKnapp Goldwing Technical Forum 7 01-18-2006 07:41 PM
