GL1500 Time Keeps Changing - Any Advice Please?? - Page 7 - Steve Saunders Goldwing Forums
 19Likes
post #61 of 81 (permalink) Old 01-19-2019, 03:39 AM Thread Starter
chris301up's Avatar
Make: Honda Goldwing
Model: 1500 SEV
Originally Posted by chris301up View Post
Another update. I have today spent a few hours working upon the meter/dash assembly once more. I have replaced most of the standard bulbs with LED's with the exception of the 'Cruise On', 'Cruise Set' and 'Low Fuel' warning lights.
At this stage everything works exactly as it should so, bearing in mind the ongoing problem I have been having, would suggest that the resistor bridging the low fuel circuit is incompatible in some way? I can confirm the resistor fitted is 470 Ohm 1/2 Watt. Maybe the value of the resistor is incorrect? I'm just not sure! Maybe someone could advise with this?
I really would have preferred to replace all the standard bulbs with LED's but, without a solution, think I'll just leave the bulbs in these three warning lights, for the foreseeable future at least.
I will also say that I agree with Briese that the Main Beam and Neutral warning lamps (fitted with LED's) tended to be a little too bright, so I removed the green and blue lenses from the front of the meter assembly, (they are just a push fit) and glued some diffusers, cut from the same milk carton used for the internal diffusers, on the inside of these and they work brilliantly. Just a suggestion for anyone else who has a similar issue?
It certainly looks like I am making progress and would like to thank all of you that helped and advised along the way.
Well everyone. It looks as though I was premature with my post. Once again I thought I'd located the problem by removing the resistors and LED's as mentioned in my post. But no! After leaving the cluster connected for approximately 24 hours, I have just switched the ignition on to have what I thought would be a final check, and the issue is still there.
A fellow Winger in the UK is hopefully sending me another cluster. My next stage has to be fitting this and see what happens I think?
If anyone has any further ideas then please comment
chris301up is offline
post #62 of 81 (permalink) Old 01-19-2019, 05:02 AM
Chris,
Maybe click on the link below and send off a private message. Refer him to your thread. If anyone has an answer he is one of the most likely.
https://www.goldwingfacts.com/forums...sierra-mc.html
redwing52 is online now
post #63 of 81 (permalink) Old 01-19-2019, 07:18 AM Thread Starter
chris301up's Avatar
Model: 1500 SEV
Chris,
Thanks Redwing 52. I have sent a message and I'll see what transpires
post #64 of 81 (permalink) Old 01-21-2019, 10:55 AM Thread Starter
chris301up's Avatar
Model: 1500 SEV
Hi all
Just a question regarding the problem that's niggling at the back of my mind?
I will be changing the LCD cluster assembly, including PCB as soon as a kind fellow Winger has posted this to me. In the meantime I have been thinking about this in more detail. If I wait for the issue to ' raise its ugly head' and I disconnect the multiplugs at the rear of the meter assembly, wait for a short amount of time and then reconnect the multiplugs, everything seems to work fine again for a few hours at least.
However, when the problem reoccurs, should I disconnect battery, wait an equivalent amount of time before reconnecting the problem remains. Surely, disconnecting the power source either at the multiplugs or at the battery should have exactly the same effect, shouldn't it? Even with a possible faulty cluster unit?
Am I thinking about this too much or completely missing something?
post #65 of 81 (permalink) Old 01-21-2019, 12:29 PM
Hi all
I would think it would have the same effect. No thoughts come to mind as to why not.
post #66 of 81 (permalink) Old 01-21-2019, 12:34 PM Thread Starter
chris301up's Avatar
Model: 1500 SEV
Thank you Dave. I didn't think it should. It has to be the cluster unit I would now think?
post #67 of 81 (permalink) Old 01-21-2019, 05:10 PM
Hi all
What if there were wires that have high resistance short in the harness that is before the plug. If you disconnect the plug you might eliminate the short temporarily. If you disconnect the battery you just take power away temporarily. I had a relay that worked like that a few times. Had an issue and unplug the relay, plug it back in and all was well until the next time the relay was activated. Then the issue returned until you unplugged the relay again. The relay had a short in the coil. Tha short was not good enough to pull the relay in. It was however good enough to hold the relay on once engaged.
post #68 of 81 (permalink) Old 01-21-2019, 10:19 PM
I would pretty much rule that thought out, as the cluster current draw is so miniscule as to not to be considered...
it is in the very small milliAmp range.
If that, a voltage is applied to the segments to make the LCD segments go blank, or dark.
redwing52 likes this.
What is the Forum Index?
Download it here:
post #69 of 81 (permalink) Old 01-23-2019, 10:07 AM Thread Starter
chris301up's Avatar
Model: 1500 SEV
Another update folks. I have today received, and fitted another cluster assembly, including the new LCD screen I purchased from Tanin Autoelectronix, but have not installed the LED's for the 'Low Fuel', 'Cruise On' or 'Cruise Set' warning lamps. I will wait now and see if the fault develops now over the next 24 to 48 hours or so? Fingers crossed !!!
ADDENDUM
Further to my previous post I am very pleased to confirm that the aforementioned problem hasn't recurred. I have also reinstalled the 'Low Fuel', 'Cruise On' and 'Cruise Set' LED's including resistors, and these seem to working as they should.
I think I can now confidently say that the problem was in fact a fault with the PCB within the cluster itself. If I can discover exactly what the fault is I will post my findings. In the meantime many thanks again to all who have helped along the way
AZgl1800, redwing52 and DBohrer like this.
post #70 of 81 (permalink) Old 02-24-2019, 06:33 PM
Model: Gl1500SE Trike
I have the same problem . Time changes at 10 sec. per minute thats 6 minutes per minute. after 50 miles it starts correct time. I wonder is there a battery that keeps time when bike is off?
RichGL1500$ is offline
Please, please, PLEASE !!! Chewman Miscellaneous Forum 2 12-23-2015 10:11 PM
Clock keeps wrong time. Dave B. Goldwing Technical Forum 9 03-12-2010 10:35 AM
In need of a frame, please, please, please TrackT2411 For Sale/Wanted Forum 20 07-10-2008 12:47 AM
Changing the fork oil 95 GL1500, need advice bamf_shadow Goldwing Technical Forum 1 02-11-2007 11:12 AM
GL1100 standard 1980 any advice is good advice, drking Goldwing Technical Forum 4 04-18-2006 12:05 AM
