GL1500 Time Keeps Changing - Any Advice Please?? - Page 8 - Steve Saunders Goldwing Forums
 19Likes
post #71 of 81 (permalink) Old 02-24-2019, 06:53 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Originally Posted by RichGL1500$ View Post
I have the same problem . Time changes at 10 sec. per minute thats 6 minutes per minute. after 50 miles it starts correct time. I wonder is there a battery that keeps time when bike is off?
Yes the # 13 backup fuse located in the relay box. It gets power (even when the ignition switch is off) and it powers the memory for the clock, radio presets, and CB channel.
However, you might have a "printed circuit board" issue.
DBohrer is offline
post #72 of 81 (permalink) Old 02-24-2019, 07:36 PM
GoldwingA1500's Avatar
Model: Goldwing GL1500 Aspencade
Mine does that, and it seems to be worse on high humid days. The clock will not only change, but run fast. But on dry days, it runs normally. In my case, I think my digital display might be going bonkers.
Joe
GoldwingA1500 is offline
post #73 of 81 (permalink) Old 02-25-2019, 01:53 AM Thread Starter
chris301up's Avatar
Make: Honda Goldwing
Model: 1500 SEV
No RichGL1500S. The power for the memory is taken form the 'Backup Fuse', (number 13 if I recall correctly?), 5 amp found within the relay box. There isn't a separate integral battery for this. Start by checking this fuse and go from there.
There are many posts regarding this issue which seem to plague certain GL1500's, together with suggested remedies, which seemed to have rectified this issue in some cases! I tried most, if not all of them but, in my case, they didn't work for me. A replacement printed circuit board, from a 1988 model in my case, sorted the problems in the end.
chris301up is offline
post #74 of 81 (permalink) Old 02-25-2019, 10:37 AM
I won an alarm clock once for a safety prize at work. If you unplugged it and plugged it back in, or if the electricity would go out momentarily it would run backwards. Had a good excuse if I was late for work though. They gave me the clock.
AZgl1800 and DBohrer like this.
redwing52 is offline
post #75 of 81 (permalink) Old 02-25-2019, 10:53 AM
DBohrer's Avatar
Year: 1967
The printed circuit board issues was mainly with the 1996 year and possibly a few of the early produced 1997 year bikes. Not surprised to hear the 1988 corrected your issues....!!
Psst: Chris301up, for the 1988 - 1992 the "backup" fuse is # 9 (not in the relay box).....!! !993 -2000 is # 13 in the relay box.....!!
DBohrer is offline
post #76 of 81 (permalink) Old 02-25-2019, 12:16 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
You could be driving too fast. Einstein's General Relativity sayz that time slows as you approach the speed of light.
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
post #77 of 81 (permalink) Old 02-25-2019, 01:31 PM
Monkey with a Football
Rudy's Avatar
I no longer have my 1500 but I have helped others with this problem. The reason your time shifts until the bike warms up is that Honda borked up this part of their design. They have a clock that gets set with the switch on the dash but they left the input to the clock chip too high of impedance for all conditions that a bike will experience in the real world.
Two things work against that in the environment (besides electrical noise).
1. humidity
2. contaminants between connections.
The two together can overcome the high impedence and cause the clock chip to think the adjustment switch is engaging. Even if just intermittently.
This is why your clock is doing screwy stuff until the bike warms up and drives the humidity away at the connector, despite any impurities.
This is also why cleaning things often helps but the best thing to do is to overcome the high impedance of the clock inputs where the time setting wires enter the clock module.
To do this I suggest adding a 10K ohm resistor (any wattage) to both inputs and the other end of the resistors both go to the + voltage driving the clock. This makes the inputs to the clock impedance 10k rather than higher. This overcomes both 1 and 2 above
The switches themselves normally switch to ground when adjustments are being made and since they are low impedance devices, they easil override the 10k pull up resistors. You can also use 4.7k or even less but 10k should do the job and if you get too low, you will be putting too much current thru the resistors when making time adjustments.
This problem and others like it are most often seen in high humidity areas like Florida and England. It is also seen in bikes stored over the winter in unprotected cold areas until the bike gets run and warmed up for the season.
As I said, I no longer have my GL but as I recall this is the best way to overcome the environmental optimism of the Honda engineers.
Rudy
wasn't too much fun”
Rudy is offline
post #78 of 81 (permalink) Old 02-26-2019, 10:34 AM
Bellboy40's Avatar
Year: 2000 & 1994
Rudy, can you mark up a diagram of how you mean for the resistors to be inserted? Is it on the ckt board where the hour/min switch has its input?
Thank you for your expertise. Haven't seen you on the forum for a while. Good to see you again.
Larry
-- Albert Einstein
Bellboy40 is offline
post #79 of 81 (permalink) Old 02-26-2019, 10:55 AM Thread Starter
chris301up's Avatar
Model: 1500 SEV
Yes I agree. Mine is 1997 so backup fuse in relay box
post #80 of 81 (permalink) Old 02-26-2019, 11:40 AM
Rudy's Avatar
Thanks. Glad to be back. As I said I no longer have my bike. If I did I'd use a voltmeter to confirm the three wires coming from the adjuster switch.
First I'd make sure the green/black wire is in fact ground. Next I'd switch on aux power to light up the LCD and confirm that the other two wires for the adjuster switch are around 5vdc and not 12vdc.
All that being true, my diagram markup pretty much shows the changes recommended. It doesn't matter where along the wires involved that the resistors should be applied but since it's possible to do so externally to the clock module, I'd avoid getting further inside it.
All that said, this markup assumes the following three things:
1. The green/black wire is the common of the switch and it is ground.
2. If the common to the switch is ground then the other two wires must float to some + voltage for the switch to pull down to ground when each adjustment is made.
3. Based on experience, that the + voltage the two non-ground wires to the switch are floated to no more than +5vdc. I wouldn't want to try to force-float the clock inputs to 12v if the inputs expect no more than 5v even though they probably have over-voltage clamping diodes on the inputs.
This is why I recommend someone confirming the 3 wires with a meter before adding the resistors.
I chose 4.7k resistors rather than 10k because I wanted 1ma pull ups to overcome humidity and dirt vs the lesser .5ma the 10k resistors would have provided.
flylow likes this.
Rudy
Rudy is offline
Please, please, PLEASE !!! Chewman Miscellaneous Forum 2 12-23-2015 10:11 PM
Clock keeps wrong time. Dave B. Goldwing Technical Forum 9 03-12-2010 10:35 AM
In need of a frame, please, please, please TrackT2411 For Sale/Wanted Forum 20 07-10-2008 12:47 AM
Changing the fork oil 95 GL1500, need advice bamf_shadow Goldwing Technical Forum 1 02-11-2007 11:12 AM
GL1100 standard 1980 any advice is good advice, drking Goldwing Technical Forum 4 04-18-2006 12:05 AM
