Latter model windsheild trim - Steve Saunders Goldwing Forums
post #1 of 11 (permalink) Old 12-30-2018, 06:35 PM Thread Starter
unclet1's Avatar
Year: 1992
Model: 1992 GL1500A Lehman Trike
I have '92 GL1500A that has a bushed looking panel between the windshield and headlight. There is also a black finned panel below the brushed panel. Question is is it possible to replace these two part wih the chrome single panel from a later model say '98 or so with the vents? I hope I didn't confuse with the description .
Life is not a journey to the grave with
the intention of arriving safely
in a pretty & well preserved body,
but rather to skid in broadside,
totally worn out & proclaiming,
Wow, What a Ride!
Current bikes:
1966 Honda Dream (CA77)
1968 Honda Dream (CA77)
1974 Honda Z50
1998 Honda GL1500 (Aspencade)(SOLD)
1992 Honda GL1500A Lehman Trike
1986 Honda TLR 200 Reflex
unclet1 is offline
post #2 of 11 (permalink) Old 12-30-2018, 09:25 PM
Year: 1990 1500 Goldwing/Motortrike Florida trike 2008 1800 Goldwing/Roadsmith Kentucky Trike
I did it to my 1990 1500 and it works great but you need to change the windscreen gasket seal cause the 1998 is different and the adjustable windshield will not stay up
limpy45 likes this.
eastkytriker is offline
post #3 of 11 (permalink) Old 12-31-2018, 04:32 AM Thread Starter
unclet1's Avatar
Year: 1992
Thanks for the info.!
Wow, What a Ride!
Current bikes:
1974 Honda Z50
unclet1 is offline
post #4 of 11 (permalink) Old 12-31-2018, 07:04 AM
Andy Cote's Avatar
I did this to my 88 as well. I did not have an issue with the windshield sliding down but when I moved the seal from the original to the new, I didn't use enough glue to attach it and next time I took it off had to re-glue it.
I used an aftermarket kit from Showchrome. Don't think they make it any more but someone has one in stock - maybe. This kit includes a bracket that attaches to the headlight assembly with longer mounting bolts. The bracket holds the bottom of the trim in place. the trim slides onto the bracket and then moves a little to one side to hook on. Somewhat of a PITA to get lined up but after a couple tries I got the hang of it.
Might as well replace the little black grill under the headlight and the painted rings at the mirror mounts with chrome ones at the same time. Those can still be had and make it look complete.
DARKSIDE #1500
2015 Goldwing - basic black
Ham Extra Class AC1R
Andy Cote is offline
post #5 of 11 (permalink) Old 12-31-2018, 09:41 AM
DBohrer's Avatar
Model: '99 Gold Wing SE
Message deleted........
DBohrer is online now
post #6 of 11 (permalink) Old 12-31-2018, 11:08 AM
joe in calif's Avatar
Good advice but I haven't seen the after marker ones with the badges on them. I think the badge, like the HONDA letters are sold separate and if I recall right they only apply with 2 way tape and there are no alignment holes on the chrome trim piece. When I removed the HONDA letters from the front of my wing there were no holes in the panel.
A NEW START ON 1/20/2017
joe in calif is offline
post #7 of 11 (permalink) Old 12-31-2018, 11:47 AM
DBohrer's Avatar
Deleted....
post #8 of 11 (permalink) Old 12-31-2018, 12:19 PM Thread Starter
unclet1's Avatar
Year: 1992
Thanks for all the info. Now to locate the parts.
Wow, What a Ride!
Current bikes:
1974 Honda Z50
unclet1 is offline
post #9 of 11 (permalink) Old 12-31-2018, 10:31 PM
Bluewaterhooker0's Avatar
Make: Goldwing SE
Model: '97 GL 1500SE
Available at Cyclemax https://cyclemax.com/inc/sdetail/gl1...blem/86/174565
Thomas Paine December, 1776
Bluewaterhooker0 is offline
post #10 of 11 (permalink) Old 01-01-2019, 10:38 AM
DBohrer's Avatar
Deleted...
Will a speedo off a 80 model work on an 82 model??? redbaron Goldwing Technical Forum 3 11-26-2008 10:39 AM
GL1500 Windsheild McTavish Goldwing Technical Forum 3 06-03-2006 05:21 PM
Howto clear up light scrathes on my windsheild Muaymendez Goldwing Technical Forum 15 05-06-2006 06:13 PM
Firecreek windsheild for GL1500 cldryder Goldwing Technical Forum 2 08-16-2005 09:50 PM
84 Aspy Carbs: California model to U.S. Model m1buck Goldwing Technical Forum 11 07-19-2005 12:42 PM
