Plastic connector bodies for electronics. - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 11 (permalink) Old 01-15-2019, 01:17 PM
briese's Avatar
Originally Posted by BLUTHUNDR31 View Post
I see the 2 pin connectors and pins (male/female) but I do not see the "crimping tool" necessary to crimp the pins to the wire. Do you folks just solder the wire to the pins?
The small amount of "wiring" I did on my beast was to snip the OEM pins and replace with .093 Molex pins and connectors. I acquired a Molex crimping tool and it works well. A quick solder and shrink tubing finishes the job. Is there a drawback with using Molex instead of the OEM pins/connectors?
The crimping tool is available through Electrical Connection. https://electricalconnection.com/ind...-hitachi-type/
I normally will just solder the pins onto the wire after using the crimping tool.
The only draw back with using Molex connectors is that they do not physically mate up with the Hitachi Style connectors on the bike. Electrically they work as advertised. With the Hitachi style connectors you can fabricate plug and play harnesses for the bike. Using Molex, you have to modify the wiring on the bike to mate things up.
limpy45 and BLUTHUNDR31 like this.
1998 - GL1500 w/175,000 miles
2003 - GL1800 w/106,000 miles
briese is offline
1980-81 1100 carb bodies CWN For Sale/Wanted Forum 0 03-16-2014 11:56 AM
plastic to plastic 1/4 mph collision THEBIGRED1 Goldwing Technical Forum 9 05-23-2011 03:13 AM
GL1200A Regulator Connector - One Connector Melted WingMan71 Goldwing Technical Forum 12 09-30-2010 06:12 PM
Throttle Bodies (injection version) ? maldini Goldwing Technical Forum 3 08-16-2006 03:57 PM
CB repair by Sierra Electronics dirkfour4 Goldwing Technical Forum 11 01-04-2006 06:43 AM
