Stainless brake lines for 1500 - Page 2 - Steve Saunders Goldwing Forums
 13Likes
post #11 of 15 (permalink) Old 01-18-2019, 12:14 PM
Year: 1992
Model: Aspencade 1500
Vacuum or pressure bleeding works fine with empty lines. Even manual bleeding will work, but you might need a lot of patience with that method. As long as HF pump pulls vacuum, it will work. Doesn't take a lot, to get the job done. Be sure to keep brake fluid out of the pump.
RambozoClown is offline
post #12 of 15 (permalink) Old 01-18-2019, 12:33 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Originally Posted by toolcraft4100 View Post
...Are you saying that you have one hose that goes from the RMC to the rear caliper. And that it replaces the two OEM hoses and the OEm pipe that goes between them?
Yes
Here's my installation (both brake and clutch lines), attaching with Stainless Zip Ties and Split Rubber Fuel Line
limpy45 likes this.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #13 of 15 (permalink) Old 03-11-2019, 07:29 AM Thread Starter
Toolcraft4100
toolcraft4100's Avatar
Make: Goldwing
Model: '91 Aspencade
Thank you
Alex, I really appreciate the pics and your effort to post them. I need to study a few of them better to really catch what I am looking at.
toolcraft4100
toolcraft4100 is offline
post #14 of 15 (permalink) Old 03-11-2019, 07:40 AM Thread Starter
Toolcraft4100
Make: Goldwing
job started
I finally got a chance to work on the brake line swap. Got the two front lines done. It wasn't as hard as I thought it might be, but a couple of tasks were a royal PITA! The hardline-to-hose connection for the left caliper was ridiculous! And both the brackets across the front on that line were very frustrating.
Can someone give me a tip on how to access the connection under the tank? Do I need to remove the alternator?
toolcraft4100
post #15 of 15 (permalink) Old 03-11-2019, 11:44 AM
I ran the Clutch Line Outside the frame, as shown:
...and the right (Rear Brake, Front Left Brake) line as shown: (Had to remove the carb, for access)
I void warranties
KJ6QFZ
Dark Side #590
Replacing GL1500 brake lines with stainless steel lines jlbc212 Goldwing Technical Forum 15 01-21-2013 11:03 AM
1500 Stainless Steel Brake Lines HogansWing Goldwing Technical Forum 5 01-09-2010 06:10 PM
Brake Lines Stock vs. Stainless brandonscaldwell Goldwing Technical Forum 14 09-19-2006 12:53 AM
Stainless brake lines keener Goldwing Technical Forum 18 02-13-2006 02:33 PM
Stainless Brake Lines - Again! keener Goldwing Technical Forum 10 11-14-2005 06:25 PM
