1500 lifted by Chain Hoist - Steve Saunders Goldwing Forums
 18Likes
post #1 of 22 (permalink) Old 01-18-2019, 07:39 PM Thread Starter
randylexus's Avatar
Model: 2000 GL1500SE
I have several things to do to my 1500 during the next several weeks and plan to use the chain hoist in my shop to lift it, mainly for tire changes, polishing mufflers, etc. Has anyone done this with their bike, and if so, where did you find the best locations to be for the support straps? Obviously, the frame is the
place to offer best support and is crucial to handle the weight, so are there any
specific places on the frame that are suitable for attachment? I realize that a good lift table or motorcycle jack will work as well or better, however I want to get the bike to near eye level where my tired old eyes can better see what I am doing! (Just turned 72 few days ago) Any suggestions will be appreciated!
Current rides--
2000 Gl1500SE
1999 Suzuki Intruder 800
1998 Yamaha Virago 1100
Past rides---
1975 GL1000
1978 GL1000
1987 Gl1200
randylexus is offline
post #2 of 22 (permalink) Old 01-18-2019, 07:56 PM
Yup...I do it all the time. First remove the seat. The two threaded bosses that hold the seat ar good mounting points. The third point is to choke the neck of the triple tree. Run the front strap through the loop made by the rear strap. Move the loop up or down the front strap until you find the perfect balance. Snap a vice grip between the two straps so they can not slide and lift it right up in the air. Be careful of wiring and other things around the neck so you don't pinch anything when you choke it. 3 point lift. The two seat threaded bosses and the neck of the bike.
AZgl1800, limpy45, dwade and 1 others like this.
redwing52 is offline
post #3 of 22 (permalink) Old 01-18-2019, 08:40 PM Thread Starter
randylexus's Avatar
Thanks Mike, just the info I needed!
Ride long and ride safe!
Randell
Current rides--
2000 Gl1500SE
Past rides---
1975 GL1000
1978 GL1000
1987 Gl1200
post #4 of 22 (permalink) Old 01-18-2019, 11:31 PM
Randell
Hard to explain over the computer but I think you get the jist of it. It's like a triangle. You might have to adjust the position of the hook fore and aft until you get it just right. Use a vice grip on both sides of the hook to be sure it stays in the balanced point. The front wheel may turn left or right but it makes no difference.
post #5 of 22 (permalink) Old 01-19-2019, 07:42 AM
Andy Cote's Avatar
A couple thoughts.
Working from memory I'm thinking the seat mounting bosses are forward of the subframe bolts. If so, following is a non-issue. But the subframe that holds the trunk, rear fender and panniers to the main frame is held on by two bolts under the seat and two near the front of the panniers and these bottom two are in slotted holes. Bottom line is do not lift using this rear subframe. Not safe to hold the weight.
I would rather use one of the load equalizer things rather than the vice grips. Example: https://www.harborfreight.com/2-Ton-...ler-60659.html
While I understand not having to bend over, getting the bike that high also means you have to lift the tires up high to put them on. Think about which is the bigger challenge.
Oh yeah.
limpy45 and dwade like this.
DARKSIDE #1500
2015 Goldwing - basic black
Ham Extra Class AC1R
Andy Cote is offline
post #6 of 22 (permalink) Old 01-19-2019, 09:47 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Originally Posted by Andy Cote View Post
...While I understand not having to bend over, getting the bike that high also means you have to lift the tires up high to put them on....
Likewise, how are you going to Un/Torque the Axle Bolt (75 Ft-Lb, as I recall), while it's hanging?.. or adjust for Weight Shift if the Rear Wheel or Final Drive is removed?
limpy45 likes this.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #7 of 22 (permalink) Old 01-19-2019, 11:55 AM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
What goes up, must come down. It’s a slick way to work on the bike with no platform or clutter under foot. I use a man-power hoist and it’s rather slow. 95% of the time I use the small bike jack. I also have a 30”x24” stout table I can drop the bike on.
I had to do some welding on the centerstand last year and lifted the bike straight up from behind and was able to get pretty good access for a amateur welder like myself.
After doing this, I have wondered if I couldn’t do the same from the frame neck and get it enough to lubricate the starter clutch pins. ??? I might try it this spring.
Ekvh1 is offline
post #8 of 22 (permalink) Old 01-19-2019, 12:25 PM
CrystalPistol's Avatar
Never contemplated doing it to one of my wings, but did do it to my Trident sans tank & seat . it's gone now sold, but getting it "up there" made some things easy.
...(Candy Spectra Red )
CrystalPistol is offline
post #9 of 22 (permalink) Old 01-19-2019, 02:11 PM Thread Starter
randylexus's Avatar
Thanks to all who had suggestions and gave advice, very much appreciated!
I now have the bike in the air. Wish I had known about the load equalizer, and will probably lower the bike to normal floor level to do the torque/untorque and weight shift adjustment. Glad you brought that to my attention Alex, seems like there's always a few things I fail to consider!
Randell C.
Current rides--
2000 Gl1500SE
Past rides---
1975 GL1000
1978 GL1000
1987 Gl1200
post #10 of 22 (permalink) Old 01-19-2019, 02:43 PM
This is how I work on mine. Sure makes a lot of things easy.
redwing52, Dodge, dwade and 1 others like this.
Hoist for shop Roadyrider General Motorcycle Discussion Forum 21 11-02-2016 01:55 PM
Space-X #9 lifted off this morning AZgl1800 Miscellaneous Forum 2 04-21-2015 10:01 PM
Have you ever lifted your 1500 without a jack agnogel Miscellaneous Forum 3 06-19-2011 11:31 AM
Loud noise around 1000-1500 RPM. I would say chain sound coming from rear of engine. newbiker Goldwing Technical Forum 5 08-01-2007 05:16 PM
Chrome Timing Chain Cover Set Littlejohn Goldwing Technical Forum 7 10-22-2004 09:52 AM
