1997 Goldwing GL1500 Asp jerking again under load below 2,000 - Page 3 - Steve Saunders Goldwing Forums
 9Likes
post #21 of 53 (permalink) Old 02-10-2019, 09:46 AM
big PIA
MysticFour's Avatar
Originally Posted by GoldwingA1500 View Post
Originally Posted by MysticFour View Post
cost of shipping plus $10.00
Since I went up to 2002 after the 1500 got totaled it is no longer doing me any good. I think I should be on the lookout for a GL1800 repair manual myself
Sorry I haven't gotten back to you. Yes I am interested in buying the GL1500 manual. Does it cover 1997 Goldwings? And how shall I purchase this from you? Money Order? PayPal? Ebay? Send me a PM (private message) and I'll PM you the information you might need...or give me a ring...I can PM you my mobile number. How much will shipping cost?
Joe
I just went and grabbed my book, it's for 1988 - 1992
Not sure how useful it would be
File Type: jpg 1549813540550784180043579609040_1549813560227.jpg (121.2 KB, 6 views)
MysticFour is offline
post #22 of 53 (permalink) Old 02-10-2019, 06:15 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
There are differences regarding what is controlled by the 30-amp and 55-amp fuses between the 1988 - 1992 manual and the 1993 - 2000 manuals.
Also differences regarding what is controlled by the Tail Main Relay # 3.
Most other items would be about the same.
If I had a 1997, I would want a manual with the correct electrical schematics.....but that's just me............!!
DBohrer is online now
post #23 of 53 (permalink) Old 02-10-2019, 06:53 PM
big PIA
MysticFour's Avatar
He passed on it for that reason, another member has a 92 that is taking it instead
DBohrer likes this.
post #24 of 53 (permalink) Old 02-12-2019, 12:29 PM Thread Starter
GoldwingA1500's Avatar
Model: Goldwing GL1500 Aspencade
My coolant temp sensor (under the right intake manifold) for my GL1500 came in today. Does anyone have instructions on how to replace the sensor? I'm hoping this might be the cause of poor fuel mileage. I'm still going to remove the carbs (to replace the float needles) and the coils (to check for cracks and to perform an ohms test).
Has anyone ever replaced the sensor in question? If so, could you provide instructions? I do not have a book for the 1997 GL1500
Joe
GoldwingA1500 is offline
post #25 of 53 (permalink) Old 02-12-2019, 12:48 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Joe
As I recall, you need to remove the Right Fan Housing, then just reach in to unscrew it for replacing... probably want to drain the coolant first.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #26 of 53 (permalink) Old 02-12-2019, 01:27 PM
Alan_Hepburn's Avatar
Year: 1994
Model: GL1500SE
It's been a while, and I don't remember all the details, but we had to remove the tupperware from the front of the bike, the sides of the bike, and the top of the bike. You need to remove the cooling fan on the right side - it can be a chore to get it out, and back in. With the fan out of the way you can reach in and grab the sensor - we didn't have to drain the coolant, but a bit will leak out when you remove the sensor. Once you get it all back together you want to start the engine, WITHOUT TOUCHING THE THROTTLE. Let it idle until the fans come on and go off - this resets the engine computer. If you haven't drained the coolant, then some will have dropped onto the engine while you were swapping the sensor - this will generate copious amounts of steam while the engine is running; don't worry - it'll clear up!
I wish I had thought to take a bunch of photos to do a how-to article...
Alan Hepburn
1994 GL1500SE with a California Sidecar
San Jose, Ca
Alan_Hepburn is offline
post #27 of 53 (permalink) Old 02-12-2019, 02:10 PM
Model: 1993 GL 1500
I don't know where to start, the temp sensor will not effect fuel mpg. If the floats are leaking you need to fix the carb's and maybe change the plug's if they show sign's that they were running rich. Check the carb diaphragms for leaks, they will cause the bike to not take gas. Expensive $200.00 for both only buy the Honda OEM. Ask how I know. After you get the bike running with the carb's fixed balance the carbs with each other. You need some kind of gauge, I bought some with fluid in them and you set one carb to the other. I could not balance them by ear or other methods. Once you do all that start looking at the coils and wire's. I think your carbs are not right and look for vacuum leaks the hose's under the carbs and the hose's from the left head. and all the other hose's. The carb's have to be right or that bike will not run right. also your going to have the fan out to replace the sensor might as well pull the other one and fix the carb's. Just my 2 cents
Jerry Burns is offline
post #28 of 53 (permalink) Old 02-12-2019, 04:22 PM
DBohrer's Avatar
Year: 1967
Hey Joe,
Are you referencing the "Carburetor Coolant Thermal Valve" page 5-14 OR "Coolant Temperature Sensor" page 5-17.....???
Look at the attached pages....!!
post #29 of 53 (permalink) Old 02-12-2019, 04:33 PM
DBohrer's Avatar
Year: 1967
Fans don't need to be removed to do carb work.....!!
Plus the left fan is more difficult to remove/replace than the right fan.
post #30 of 53 (permalink) Old 02-12-2019, 10:49 PM
Model: 1993 GL 1500
DBohrer, you are right about the fans, left is much harder to get out and in. There is a bracket in the back , upper right side that if you take that bolt out it gives a little slack to get the fan back in. Thats sitting and facing the left fan. Having both fan's out makes it a little better for me. Those's pages from the manually should help him change that sensor. I replaced my jet's in the carb's with what was in a kit the main jets were 48's the bike would not accelerate and would bog down if I rolled the throttle on to fast. I put the stock 58 jet's back in and replaced the diaphragms that was over 2 years ago and no problems. I get 35 to 39 mpg depends on where I'm going. I do think different years had different size main jets because of smog law's. I have found if I try to fix to many things at once I don't have much luck. That's what I was trying to say, get the carb's right and vacuum lines back where they go and the bike should run. If not look at the spark. Works for me but I just guessing.
1997 Goldwing GL1500 Jerks under 2,000 RPM GoldwingA1500 Goldwing Technical Forum 149 07-04-2018 01:52 PM
GL1500 Transmission Howling under load hypokets68 Goldwing Technical Forum 8 04-27-2014 11:10 AM
83' GL1100 Head gasket, Oil light 2nd gear jerking MarkV Goldwing Technical Forum 12 11-02-2013 11:28 PM
GL1500 bad bearing noise under load DAN D Goldwing Technical Forum 3 04-24-2012 10:20 PM
GL1500: pops out of first to neutral under load jkulbeth Goldwing Technical Forum 10 04-26-2010 10:56 PM
