GL 1500 SE speedometer - Steve Saunders Goldwing Forums
 9Likes
post #1 of 18 (permalink) Old 02-19-2019, 09:39 PM Thread Starter
Well, my GL1500SE speed indicator is off just a bit like all of them. About 3 mph faster than actual ground GPS speed at 60 mph. So, while I have most of the fairing apart to do some other wiring work, I figure might as well dig into gauge cluster and see if I can do to this speedo like I did to my 81 VW Rabbit. Took cluster apart and then holding the drum the magnet on the end of the cable spins, I moved the needle back about 2 mph. By the way, there is NO fluid to leak out of the speedometer. I have NO idea how this got started many years ago. But, it had to be someone who has never been inside a automotive speedo or any one for that matter. Now just have to wait for the spring thaw, and the way our weather has been this winter, that will possibly be around May 30 or so. Then I will compare it to my GPS. That is all for tonight.
limpy45 is offline
post #2 of 18 (permalink) Old 02-19-2019, 10:05 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
If you ran Avon tires your speedometer would be accurate. I have ran Avon tires for the last 11 years on my GL1500. My speedometer is right on with a GPS.
Hope you haven't messed up your speedometer....!
DBohrer is online now
post #3 of 18 (permalink) Old 02-19-2019, 10:14 PM
We used to do that with some BMW speedometers years ago. They were the other way, showed too slow.
post #4 of 18 (permalink) Old 02-19-2019, 10:20 PM
I did that on my 12. Now it reads a little slow in the lower ranges, making it necessary to be mindful in school zones where enforcers are less tolerant.
post #5 of 18 (permalink) Old 02-19-2019, 10:36 PM
rayjoe's Avatar
Sorry, but you must be a young guy. Old speedos and tachometers had some kind of damper fluid in them. It was in a little tin pot that the needle was attached to. Think old English bikes and cars.
Rayjoe
rayjoe is offline
post #6 of 18 (permalink) Old 02-20-2019, 05:04 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
I haven't seen any damper oil inside either, but there are notes in the service manual about it.
Erdeniz Umman is online now
post #7 of 18 (permalink) Old 02-20-2019, 08:48 PM
Year: 1992
Model: Aspencade 1500
I was under the impression that the damper oil was just in the fuel gauge.
RambozoClown is offline
post #8 of 18 (permalink) Old 02-21-2019, 03:11 AM
BLUTHUNDR31's Avatar
It could be an "old-wives-tale" that has carried on to tday's current market. I heard/read the same information. Both the Temp and fuel gauges would benefit from even a small amount of Dampening Fluid (IMHO).
Whenever I deal with the gauges, I subscribe to the philosophy that I DO NOT turn the gauges upside-down unless it is ABSOLUTELY necessary. The manual could be mistaken, and it wouldn't be the FIRST mistake we found in it BUT, , , why tempt fate if you don't have to?? I don't want to be the one to have to admit that I turned the gauge over and now it doesn't work right.
limpy45 likes this.
BLUTHUNDR31 is online now
post #9 of 18 (permalink) Old 02-21-2019, 10:04 AM
We must be getting old. Many years ago there was a local parts house that had a section that did gauge repair and hydraulic hoses. What a strange combination tht was. Interesting though. They could calibrate your speedometer in any way you wanted. How they did it was by really making the magnet in the drum too strong. Then they would spin the speedo on a machine. They could bit by bit demagnetize the magnet until they got it just right.
There is a super light spring in the gauge. The purpose of the oil is to dampen that spring just like shocks and springs in your car. There is only a few drops and if you turn the gauges upside down it will not hurt them if it is for a short time. If you store them upside sown you might end up with a bouncy needle on the gauge. The newer vehicles do the same thing electronically by using a capacitor in the gauge to act like an electrical shock absorber.
DBohrer likes this.
redwing52 is offline
post #10 of 18 (permalink) Old 02-21-2019, 11:05 AM
Next you'll be telling me my bike doesn't have tail-light oil...or blinker fluid!
1998 GL 1500 SE, Speedometer miles to Km, Erics Goldwing Technical Forum 9 11-26-2015 11:33 AM
speedometer washers 1500 gl SE GW FNGGW2012 Goldwing Technical Forum 7 07-23-2012 07:41 AM
GL 1500 speedometer not working deradler1 Goldwing Technical Forum 2 09-14-2010 07:29 PM
88 gl 1500 speedometer gbob12 Goldwing Technical Forum 4 08-03-2009 07:56 PM
Speedometer Cable 97 1500 SE kilroy965 Goldwing Technical Forum 1 07-12-2007 01:47 PM
