GL1500 identifying gizmos - Page 12 - Steve Saunders Goldwing Forums
 22Likes
post #111 of 131 (permalink) Old 04-29-2019, 06:29 PM
Originally Posted by PioyrGL1500 View Post
- this question seamce to be easier: next to thermostat are two gauges for temp one is probably for fan motor activation when overheated and second is for temp gauge showing the current fluid temp. I have already mounted aftermarket temp gauge and do not know which sensor should I connect to. Or maybe there is another sensor somewhere else???.ufffff...
The sensor for the temp gauge is on the thermostat housing, the one on the right side with the green connector is for the engine control module, the fan switch is on the bottom of the left radiator.
post #112 of 131 (permalink) Old 04-30-2019, 06:14 AM Thread Starter
Year: 1990
Make: Gold Wing
Model: GL1500
Oops, that didn't work right, but try this:
https://www.goldwingfacts.com/forums...uel-light.html
Thanks a lot. I did already order thermistor in UK on eBay.
RL2004-582-97-D1
PioyrGL1500 is offline
post #113 of 131 (permalink) Old 05-31-2019, 03:29 PM Thread Starter
Year: 1990
Make: Gold Wing
Model: GL1500
It's been a long time I did not post anything...so now you can take a look how my Baby looks like. I'm riding Her....
AZgl1800 likes this.
post #114 of 131 (permalink) Old 05-31-2019, 05:06 PM
Looks very nice.
Kudos on sticking with it until you got it done.
post #115 of 131 (permalink) Old 05-31-2019, 05:09 PM
Year: 1998
Model: GL1500 SE
Looks good, Are you going to fab up any kind of covers for the sides or is that the look you want?
Rickf1985 is offline
post #116 of 131 (permalink) Old 05-31-2019, 05:20 PM
Year: 1992
Model: Aspencade 1500
One thing to keep in mind is that the stock low fuel light requires the proper sized incandescent light bulb to drive it. It will not function properly with an LED. (It will be on all the time.) You can use a 470 Ohm, 1/2 watt resistor in parallel, but you may still notice a dim glow at night.
RambozoClown is offline
post #117 of 131 (permalink) Old 06-01-2019, 03:43 AM Thread Starter
Year: 1990
Make: Gold Wing
Model: GL1500
Regarding low fuel light I think it may glow all the time as you mention because of led light. But I did mount analog gauges for fuel and temp from BMW and all works properly, so may not need worning light. But will try with resistor anyway.
My work is in a progress, many issues pop up during such work and that slowes down all. Will install side covers, just looking for some for reasonable price. (I stuck with work progress because of money shortage). Now Im riding and checking what can be done more. Next steps:
- changing handlebar for smallest with risers, that will cose to change all switches and pumps,
- brake lines from ss and change that right lever will brake two front discs and foot brake only rear disc
- definitely must change rear shock absorbers for some smooth not to "hurt my spine" like I do now. I was thinking about making central shock (from BMW K1200RS) but that will not fits because of fuel tank. To many costly changes...for now.
- will be nice to have front pipes from ss but another costly thing, I did mounted already exhaust collector from ss which cosed louder exhaust but in fact could be more loud.
- looking for idea how to change intake with air filter, mean like high flow washable filter. It is just idea to change all air box. But for now no concept.
Hardcore concept is to remove fuell tank.......and replace with something smaller....but...
post #118 of 131 (permalink) Old 06-01-2019, 05:10 AM
You should leave the air filter as is, changing it may cause problems.
post #119 of 131 (permalink) Old 06-01-2019, 03:38 PM Thread Starter
Year: 1990
Make: Gold Wing
Model: GL1500
Wellllll....I was trying to ride without any airbox just bared carbs and all was working, smooth work. I did not checked high speed and fuel consumption but stil, all works. That gives me a good start for mods.
post #120 of 131 (permalink) Old 06-01-2019, 05:53 PM
Year: 1992
Without the airbox, you will typically be running too lean.
Help Identifying Saddlebag Lights-GL1500 JackfromCT Goldwing Technical Forum 29 01-04-2014 02:20 PM
Help on identifying GL1500 parts I need from getting rear ended. claydawg101 Goldwing Technical Forum 11 04-11-2013 11:24 AM
Help Identifying GL1500 Brake Light Wire w5blt Goldwing Technical Forum 5 04-12-2010 08:27 PM
Gizmos & Other Wichita Scorpion General Motorcycle Discussion Forum 14 12-21-2007 02:06 PM
I need help identifying a saddle 86vt1100 Goldwing Technical Forum 5 01-27-2006 05:05 AM
