Rim Swap - Steve Saunders Goldwing Forums
 7Likes
post #1 of 12 (permalink) Old 03-02-2019, 10:59 PM Thread Starter
Year: 1983
Model: Aspencade
Question Rim Swap
Is it possible to mount a spoked 17" wheel from a '75 GL1000 onto an '83 GL1100 Aspencade?
If so, is it a straight swap or are there mods that need to be made?
Thanks!!
Rubber down, chrome up, throttle open!!
~Gil
SchWing is offline
post #2 of 12 (permalink) Old 03-03-2019, 04:45 AM
No, it won't fit. But I have to ask why would you go from a nice cast aluminum tubeless wheel to a spoked wheel you have to use a tube with?
Bike...and Dennis and SchWing like this.
post #3 of 12 (permalink) Old 03-03-2019, 02:09 PM Thread Starter
Year: 1983
Model: Aspencade
I'm looking to set it up as something of a dual sport...was having trouble locating a 16" rear tire but I think that's sorted itself out.
My inspiration:
~Gil
SchWing is offline
post #4 of 12 (permalink) Old 03-03-2019, 02:12 PM Thread Starter
Year: 1983
Model: Aspencade
In what way(s) won't it fit? The wheel to the final drive? If that's the case is it possible to mount a final drive from a GL1000 to my GL1100?
~Gil
SchWing is offline
post #5 of 12 (permalink) Old 03-03-2019, 02:49 PM
It won't fit the final drive, I tried it just to know but don't remember exactly what the problem was. No idea if the 1000 final will fit the 1100 swing arm.
SchWing likes this.
post #6 of 12 (permalink) Old 03-04-2019, 10:26 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
It can be done if you use the 1000 swing arm and engine output shaft. The 1000 swing arm is about 2 inches shorter than the 1100. The geometry of the rear shock will need to be changed. I have to ask why you are considering this? There are a lot of bikes that are better offroad than a Goldwing.
SchWing likes this.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #7 of 12 (permalink) Old 03-05-2019, 06:25 AM
I agree. I had a KLR650, built for off road and it was too heavy for the purpose. I can't imagine hefting a 500 lb monster around in the woods.
SchWing likes this.
post #8 of 12 (permalink) Old 03-05-2019, 09:31 AM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
I don’t recall how rideable your “inspiration” bike is. It is a cool build and looks great. It is lifted enough to get the jugs up out of the way, but the angle of the driveshaft looks like it would go through u-joint knuckles left and right. It looks like it might not even work. Maybe with rider weight.
If you’re just going for tracker looks and some occasional jaunts off-road, it might be okay. A guy from Largo, Florida built an adv bike from a wing. If I can recall his name I’ll link his build and thoughts about it.
SchWing likes this.
Ekvh1 is offline
post #9 of 12 (permalink) Old 03-05-2019, 09:37 AM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
Ekvh1 is offline
post #10 of 12 (permalink) Old 03-05-2019, 12:47 PM Thread Starter
Year: 1983
Model: Aspencade
Thanks for this info!!I get that there are "better" bikes out there for this...however I'm not really looking to go offroad...I'm into long distance rides that find me occasionally running on roads where the road goes on but the pavement ends...and want to mount dual sport tires for this reason.
The GL1100 has a 16" rim and (so far) I have found exactly one tire that will fit. The GL1000 has a 17" rear rim and there are scads of tire available for that.
And besides, anyone can buy a bike that already runs!!
~Gil
SchWing is offline
GL1100 running funny after Neon coil swap - still runs funny after swap back ntomsheck Goldwing Technical Forum 8 09-18-2015 08:19 PM
83 to 82 rim swap dhrith Goldwing Technical Forum 1 07-27-2009 10:50 PM
Rim Swap Zypher412 Goldwing Technical Forum 2 09-02-2008 02:17 PM
Chrome rim swap Ebola Goldwing Technical Forum 12 09-03-2007 02:38 PM
Reasonable rim polishing quote? hermgoode General Motorcycle Discussion Forum 7 04-18-2006 10:16 PM
