GL1200 clunky shift - Page 2 - Steve Saunders Goldwing Forums
 5Likes
post #11 of 13 (permalink) Old 03-07-2019, 10:45 PM
The aftermarket pegs are for attaching to the crash bars and won't work for foot pegs. You have to get stock pegs so they will attach to the frame correctly. And they have to be for the front as the rear pegs won't work.
GL12 pegs are pretty broad compared to other bikes so they are fairly comfortable.
post #12 of 13 (permalink) Old 03-08-2019, 11:48 AM
Coyote Kid's Avatar
Model: 1986 GL1200 Aspy
I had a lot of hard shifting and missed shifts when I first got my used 86 1200 (21K miles) and only stopped with an oil change, but within 500 miles it would be back. I changed over to 5w40 Shell Rotella T6 full synthetic and in 55K miles haven't had a problem since.
Coyote Kid is offline
post #13 of 13 (permalink) Old 03-25-2019, 05:34 PM Thread Starter
Year: 1986
Model: Interstate
Thanks for the responses everyone! The solution turned out to be a little embarrassingly simple. In a nut shell, I changed my boots to a thinner pair and was able to slide my foot under and get a better lift on the shifter. The boots I was using before are waterproof insulated steel toe work boots. It was just too thick with the floor boards.
I also practiced the recommended technique, holding first gear a little longer, preloading the shifter, and quickly pulling in the clutch and shifting.
This technique works pretty well but takes a little thought. I need to get this bike out of the city soon!
Stay tuned for a post in a few days with some stories from this weekend when I changed the wiring harness to the Electrical Connection wiring harness.
SmokeySubie is offline
poll: do you think your gear change is clunky gl1500? marknewbill Goldwing Technical Forum 58 06-25-2012 06:57 PM
GL1500 clunky shifting Indianawantsme Goldwing Technical Forum 43 03-11-2012 01:34 PM
Clunky GL1100 gaillarry Goldwing Technical Forum 4 06-28-2011 09:17 AM
GL1200 clunky shifting 86 Wing Goldwing Technical Forum 19 10-01-2010 06:22 PM
clunky transmission jasonar5 Goldwing Technical Forum 16 10-25-2005 09:55 AM
