GL1200 Rear Suspension Pressure(psi)Settings - Page 2 - Steve Saunders Goldwing Forums
post #11 of 17 (permalink) Old 03-07-2019, 11:26 AM
Originally Posted by Markos View Post
Thankyou.Very helpful.Which manual is that taken from,as that's clearly the one I need as the Haynes is useless?
That is from the owner's manual.
PM sent.
post #12 of 17 (permalink) Old 03-07-2019, 02:24 PM
glhonda's Avatar
The tank does say 200-400psi,but that is a massive range.
The tank probably says 200-400kPa..and someone misread it .
glhonda is offline
post #13 of 17 (permalink) Old 03-07-2019, 03:07 PM Thread Starter
Year: 1985
Model: GL1200 Interstate
Please us the quote button so we know who you are replying to.
Sorry wasn't aware I had to do that.
Markos is offline
post #14 of 17 (permalink) Old 03-07-2019, 03:11 PM Thread Starter
Year: 1985
Yep,you're probably right,and that someone was me.Doh!
To be fair it was raining and I'd been working on the bike all day.
Still needed the advice on the range though.
Thanks
Markos is offline
post #15 of 17 (permalink) Old 03-07-2019, 05:28 PM
You don't have to, it just helps make things make sense.
post #16 of 17 (permalink) Old 03-17-2019, 10:07 AM
GoldwingA1500's Avatar
Model: Goldwing GL1500 Aspencade
I too was wondering about the correct pressure on the 1986 GL1200 Interstate because the book simply says 0 - 6 psi for the front, and 28 - 57 psi for the rear. But because I am a little short, even the max pressure forces me to tip-toe at a stop and that's with boots on. So I set mine around 15 psi; just enough air pressure to ensure oil in the strut doesn't back-flow into the service hose. I have to rebuild mine anyways, so at this point, due to it leaking oil (left side rear), the pressures do not concern me at the moment. Once I either replace or rebuild both struts (might as well do them both), then I will be meticulous about the correct air pressure for my weight. I wonder if they make a seat that is at least 1/2" inch lower.
Joe
GoldwingA1500 is offline
post #17 of 17 (permalink) Old 03-17-2019, 11:53 AM
Screw's Avatar
Model: GL1200 and GL1100
I run 45lbs in the Rear, 4lbs in the front I have Progressive springs as well. Im 260lbs Very seldom 2up. I like just enough that when I jump off the center stand, I can feel the air in the rear. if you do it a few times you will feel what Im saying. With these settings I dont get much road feel, and the grooved pavement is pretty much unnoticeable. You have to use a quick release valve to get these things just right, because they dont hold much so pressure changes quickly. A small handheld pump will work great, then you dont go over pressure.
GL1100
GL1200
KZ1000
Grizzly 600
CR250
Screw is offline
PSI in GL1100 air suspension MordiRider General Motorcycle Discussion Forum 6 02-16-2013 07:59 PM
Darkside Tire Pressure Experimenting.... What PSI's are you using? pwhoever General Motorcycle Discussion Forum 25 06-06-2012 02:16 AM
1993 GL1500 rear shock air pressure settings PurplePirate Goldwing Technical Forum 8 11-12-2010 06:50 AM
2008 rear suspension settings Lum Goldwing Technical Forum 9 06-17-2010 01:37 AM
Rear Suspension Settings GL1800 daveapace Goldwing Technical Forum 17 03-22-2010 08:22 PM
