86 1200 fuel pump - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 03-16-2019, 01:35 PM Thread Starter
Who the heck cares?
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
86 1200 fuel pump
I’m working on a friends 86 GL1200I. It runs well but I hear a loud ‘clicking’ once every 5 seconds. When I put my hand on it I feel a ‘buzz’ It’s been awhile since I played with a 1200 so I’m hoping for some input. Thanks
Ray
88 GL1500
rayworx is offline
post #2 of 6 (permalink) Old 03-16-2019, 01:52 PM
The good news is, those pumps are still available.
Not cheap but if you only have to buy one every 35 years or so...
Somewhere, I think on this site, there's a tutorial on how to replace the rubber piece that quiets the tapping. Can't find it now.
Also, make sure you don't have a pre-pump fuel restriction. The pump will tick when it hasn't got enough fuel. A dirty filter could be the problem.
post #3 of 6 (permalink) Old 03-16-2019, 02:46 PM Thread Starter
Who the heck cares?
rayworx's Avatar
Year: 1988
Model: 88 GL1500
Thanks Bike.... and thank Dennis also.
Ray
88 GL1500
rayworx is offline
post #4 of 6 (permalink) Old 03-17-2019, 12:13 AM
Hi Ray,
The theory of operation of those pumps is actually pretty simple and will help you understand why they click when the rubber bumper wears out.
The actual fuel pressure is made br a spring pushing on a diaphragm. So if you are putting a new pump on the spring is in a relative relaxed state with the piston and diaphragm all the way forward. The piston and diaphragm always move as one. You turn the key on and the electromagnet pulls the steel piston back and compresses the spring. This action pulls the diaphragm causing vacuum to suck fuel in to the pump. . Also when the piston comes back the piston will hit and open a set of points at the end of it's travel. This will open the points and shut off off the magnet. The spring is now loaded and will travel forward pushing fuel and building fuel pressure. If the pressure is high enough the piston (and diaphragm) can not travel far enough forward to allow the points to close.Now electrically the pump is just waiting for the pressure to drop, so the piston can move forward enough that the points will close again. Then the process starts all over again.
The click that you hear is the piston being suck (snapped) back by the magnet. There is a rubber disk in the pump so it does not click against the metal but time and wear destroys the rubber. The pump can function fine indefinitely if you can tolerate the click. You can disassemble and replace the disk with a makeshift disk, or replace the pump. What ever flips your flapjack.
After all my typing I found this:
https://goldwingdocs.com/forum/viewtopic.php?t=8642
redwing52 is online now
post #5 of 6 (permalink) Old 03-17-2019, 06:43 PM Thread Starter
Who the heck cares?
rayworx's Avatar
Year: 1988
Model: 88 GL1500
Great info. Thanks a bunch.
Ray
88 GL1500
rayworx is offline
post #6 of 6 (permalink) Old 03-17-2019, 08:16 PM
Seldom I can help you. Usually the other way around.
88 GL1500, No Power To The FUEL Pump. Ground Wire From Fuel Pump Burned. Willis Redd New Members Introduction Forum 5 07-06-2016 10:38 AM
fuel pump on 86 GL1200 doesn't pump mr marty Goldwing Technical Forum 1 05-31-2008 11:45 PM
fuel pump pressure on 86 1200 sei joebyoung Goldwing Technical Forum 18 01-26-2008 03:35 PM
1200 ltd fuel pump- any options beside the OEM pump? Randy Peterson Goldwing Technical Forum 13 11-03-2007 09:30 AM
86 GL1200i Fuel Pump Relay [email protected] Goldwing Technical Forum 5 03-28-2006 04:30 PM
