Rear Brake lights-What wire gauge? - Page 3 - Steve Saunders Goldwing Forums
 8Likes
post #21 of 23 (permalink) Old 03-26-2019, 07:57 AM
Las Vegas's Avatar
First let me explain myself, I’ve been a mechanic for 40 years but not on bikes, but it’s still a machine right, I know things can be tricky, the first thing I got out of ur post was u tapped into everything and that can lead to many different problems, here’s my suggestion on LED’s the nx time u purchase them make sure they come with a built in resistor it totally saves u tons of problems on why this or that doesn’t work.
Las Vegas is offline
post #22 of 23 (permalink) Old 03-26-2019, 09:02 AM
cihilb's Avatar
Model: 2012 Pearl White
Here is a chart showing wire size and length for 12 volt DC circuits. 18 gauge wire can handle 16 amps up to 10 feet long.
DaveO430 likes this.
cihilb is offline
post #23 of 23 (permalink) Old 03-28-2019, 10:28 PM Thread Starter
Model: Goldwing SE
All right, the flasher from LEDLight.com did not work. So I was resolved that the only thing that was going to work was the resistor route.
Now, where to put them? As I tested them, albeit for only a few minutes, they do start to get warm. How warm, I don't know how warm they will actually get. So I decide the best thing to do is to isolate them as much as possible and maybe somehow get then into a stream of air, but where? They aren't ugly, but I don't want them right on the front fender.
Since the bike has the majority of the cosmetic plasic off, I see what I think is a good spot, which is inside the vent tube that provides cool air to my legs when it is warm. So that's where I mounted the resistors for the front turn signals.
Here are some pictures. I had to add a little length of wire between the resistor and the wire harness. By the way, I tapped into the after market wiring harness that turns my side marker lights into flashing side markers flash with the turn signals. This way, if I don't like it, or for any reason it needs to be removed, I can remove it and just purchase another side marker harness.
I used #6-32 screws and also added a 1/4" nylon spacer between the resitor and the vent tube. I hopefully this keeps the heat from the resistor a little better isolated.
Cheers
BigDanT is offline
Fuel gauge andtemparature gauge not working and rear suspension light on ssbn729 Goldwing Technical Forum 3 03-03-2017 03:20 PM
GL 1500: rear lights, fuel gauge, temperature gauge, reverse.... have ceased to work AlpineGoldwing Goldwing Technical Forum 5 07-15-2015 05:18 PM
Idiot lights/gas gauge/temp. lights flicker FeHead Goldwing Technical Forum 2 07-15-2011 08:02 AM
5 wire to 4 wire Converter Diagram? William_86 Goldwing Technical Forum 10 07-06-2010 11:25 AM
wire up to a 4 wire trailer from 6 wire plug! vv0350 General Motorcycle Discussion Forum 3 04-10-2007 07:59 PM
