Rear Brake lights-What wire gauge? - Steve Saunders Goldwing Forums
 8Likes
post #1 of 23 (permalink) Old 03-18-2019, 09:35 PM Thread Starter
Model: Goldwing SE
I'm no electrical engineer by any means, so I'm hoping that someone out there knows the answer to my question.
What wire gauge are the wires connected to the attached connector. This connector is for the Right Rear Brake lights and Turn Signal. I need to tap into these to add a resistor for my Super Bright LEDs.
BigDanT is offline
post #2 of 23 (permalink) Old 03-18-2019, 09:40 PM Thread Starter
Model: Goldwing SE
I knot that if I cut the wires I could measure the diameter of the indiviual strand and count the number of strands to determine the wire gauge, but I don't want to cut the wire.
BigDanT is offline
post #3 of 23 (permalink) Old 03-18-2019, 09:58 PM
It's a metric gauge wire, probably a .5mm, something like 16 awg.
limpy45 likes this.
post #4 of 23 (permalink) Old 03-18-2019, 11:26 PM Thread Starter
Model: Goldwing SE
Thanks Dave O430. I was hoping to get a "definete" size verses a "Probably" size.
BigDanT is offline
post #5 of 23 (permalink) Old 03-19-2019, 12:08 AM
16 ga will do the job, 14 ga is probably too heavy for the connector.
18 ga will provide just enough power to make the brake lights burn bright, but just barely.
limpy45 likes this.
NASR 12 in Galena, IL
post #6 of 23 (permalink) Old 03-19-2019, 06:45 AM
DenverWinger's Avatar
He's just tapping in to add the load resistor, it doesn't have to glow. 18ga will be fine. But I'd cut out those tap connectors and solder the joints instead. You are asking for intermittent load resistors.
BigDan, I'd be interested in your review of the LED Stop and Turn lights, from what I've heard so far they aren't really any brighter than the incandescents. I'm working on converting the trunk and saddlebag side lights to 300 lumen LED tape from Superbright 'cause half the existing bulbs are burned out, but until they make really bright 1156/1157 I'm thinking to just stay with standard light bulbs.
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is online now
post #7 of 23 (permalink) Old 03-19-2019, 06:55 AM Thread Starter
Model: Goldwing SE
Here is the resistor that I'm using from Superbrightleds.
The current draw is 2.25A(2250MA), 6 Ohms 50 Watts
https://www.superbrightleds.com/more...g-fix/190/831/
BigDanT is offline
post #8 of 23 (permalink) Old 03-19-2019, 07:45 AM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
Dan,
Just checking, are you adding this load resister because the LED bulbs cause the turn signal flash rate to change? If that's the case, maybe consider swapping the analog flasher unit for a digital instead of the load resister. Should be plug-and-play with no cutting, no splicing, no soldering necessary.
AZgl1800, DaveO430, flylow and 1 others like this.
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is online now
post #9 of 23 (permalink) Old 03-19-2019, 05:33 PM
Originally Posted by OldSchool_IsCool View Post
Dan,
this is the preferred method to fix the issue, no need to add "junk" to make things work.
limpy45 likes this.
post #10 of 23 (permalink) Old 03-19-2019, 05:40 PM Thread Starter
Model: Goldwing SE
Where can I find this digital flasher?
BigDanT is offline
Fuel gauge andtemparature gauge not working and rear suspension light on ssbn729 Goldwing Technical Forum 3 03-03-2017 03:20 PM
GL 1500: rear lights, fuel gauge, temperature gauge, reverse.... have ceased to work AlpineGoldwing Goldwing Technical Forum 5 07-15-2015 05:18 PM
Idiot lights/gas gauge/temp. lights flicker FeHead Goldwing Technical Forum 2 07-15-2011 08:02 AM
5 wire to 4 wire Converter Diagram? William_86 Goldwing Technical Forum 10 07-06-2010 11:25 AM
wire up to a 4 wire trailer from 6 wire plug! vv0350 General Motorcycle Discussion Forum 3 04-10-2007 07:59 PM
