GL1200 Whining noise at speed - Page 2 - Steve Saunders Goldwing Forums
 7Likes
post #11 of 11 (permalink) Old 03-23-2019, 10:22 PM Thread Starter
DarkWing Duck's Avatar
Year: 1978
Model: GL1000
Yeah, maybe. Lubing the cable is a quick and easy job, so I thought I'd be optimistic.
Lubing the speedo requires mega disassembly to get the unit out.
Originally Posted by cihilb View Post
Also check the speedometer drive gear on the front wheel. If it's dry on grease it will make a whining sound. The noise may be transmitting up the cable. It's really hard to tell where the sound is actually coming from when riding.
Another remote possibility is the timing belts or belt tensioner.
@Bike...and Dennis I have an '84 Standard model so getting my front wheel off is pretty easy...actually everything on this bike is easy to fix, imo. I have pulled the motor 3 times and the last time was to replace it with an 87 cause my 84 motor decided to crap out. I know most people wouldn't want to pull a Goldwing motor, but I love this bike too much to let it die. Even when I wrecked and hit a curb head on and totaled my front end, I replaced every part(busted wheel, forks, triple tree, windshield, all kinds of stuff, got them used off ebay, but still)
I haven't gone on a decent ride yet but my quick trips around town have been quite so far since I lubed it. I have a new set of timing belts I'm going to put on pretty soon. Thanks for the responses. Now if I could just figure out where this oil leak is coming from so I don't have to slide a rag under it every time I pull it in the garage. LoL. It may be brake fluid considering my clutch lost pressure after sitting for 6 months. (had to crack the 14mm banjo and bleed it at the master cylinder to get the air out!) But it was a little low on oil too and I had just changed it before parking so.....not sure
This bike is definitely a labor of love.
DarkWing Duck is offline
GL1200 radio whining noise winger43 Goldwing Technical Forum 4 05-29-2012 03:29 PM
GL1500 Engine whining noise - sounds like alternator, but it isn't! serendib Goldwing Technical Forum 13 02-20-2012 07:15 AM
Alternator whining noise wing89nut Goldwing Technical Forum 3 04-20-2009 05:42 PM
whining noise 1500se churchhillmike Goldwing Technical Forum 2 03-09-2009 01:59 PM
Whining noise from rear of bike at 95 mph + lakelander General Motorcycle Discussion Forum 12 08-01-2007 11:19 AM
