Engine stalls 2002 GL1800 - Steve Saunders Goldwing Forums
 15Likes
post #1 of 19 (permalink) Old 03-30-2019, 07:27 AM Thread Starter
Winging Ed
I have the first ever technical problem with my 2002 Goldwing and I'm looking for someone who has had this issue and can point me in a direction.
I bought the bike new in 2002, and it only has 32k miles. I have always diligently did the maintenance almost to be considered obsessed.
Here is what started happening...
After only riding about a mile or two the bike "hiccups" a couple times then the F1 light comes on and engine dies. I pull over to the side of the road and begin trying to restart it. The F1 light is acting perfectly normal, everything else looks and sounds normal, but the engine turns over and will not hit. The only other symptom is the reverse does not work, the reverse indicator comes on but pressing the starter button does nothing.
Then, after trying and trying, it starts. Runs another mile or two and does the same thing over again.
I think it's acting like a fuel pump issue, but the sounds from it are the same as always and the F1 light is acting normal. Also, the fact that reverse will not energize until after the engine finally starts again tells me this could be an electrical problem.
Anyone had this happen before, or have any thoughts?
WingingEd is offline
post #2 of 19 (permalink) Old 03-30-2019, 09:08 AM
Reverse will not work if the engine is not running so that's normal. I'm thinking maybe the crank position sensor. If you stop and put the sidestand down and crank it for 10 seconds you may get a flash code from the FI light.
Bike...and Dennis likes this.
post #3 of 19 (permalink) Old 03-30-2019, 09:41 AM
Just did this on my car. It was the CPS.
post #4 of 19 (permalink) Old 03-31-2019, 01:46 AM
I wonder if Dave misspoke when he mentioned the possible crank sensor. That maybe he meant to say camshaft position sensor. I do not believe they have a crank sensor as the pulse generators do that job??? It is possible the PG's have failed.
It is not unusual for the reluctor and pickup type sensors to not set codes. The reason is that the signal can just scramble and not necessarily quit. Also the ECU can interpret the lack of signal as the key being on and engine not cranking. I have had some success diagnosing these sensors 9when no code is set) by running the engine until it quits. Then spray the sensor with a garden hose to cool it off. If it starts again there is a good chance the sensor has failed. Unfortunately if the engine still does not start that doesn't mean the sensor is good.
Just for curiosity when it won't start crank the engine and see if the tach measures some RPM. Good hint maybe??? When the engine quits follow the instructions below but do not turn off the key when it quits.
SELF-DIAGNOSTIC DATA INDICATION
PROCEDURE
Place the motorcycle on its side stand.
Turn the ignition switch to “ON” and engine stop
switch to “ .”
The malfunction indicator lamp (MIL) comes on for
a few seconds, then goes off.
Start the engine and let it idle.
• If the engine will not start, turn the starter motor
for more than 10 seconds and check that the MIL
blinks
If the MIL does not blink, the ECM has no problem
data.
If the MIL blinks, read and record how many times
the MIL blinks, and determine the cause of the
problem .
• The MIL will start blinking when the side stand is
lowered and the engine speed is below
1,500 rpm. If the side stand is retracted or the
engine speed is above 1,500 rpm, the MIL will
illuminate and stay on.
redwing52 is online now
post #5 of 19 (permalink) Old 03-31-2019, 05:45 AM
No, I did not misspeak, it has a CKP sensor as well as a CMP. Pulse generator is just another name for the same animal. The ECU can detect the lack of signal from the CKP if is getting a signal from the CMP.
post #6 of 19 (permalink) Old 03-31-2019, 12:26 PM
Didn't mean to step on your toes. It was only my intention to point out that the crank sensor has been known for over 30 years as pulse generators. Just to avoid some confusion. I agree the symptom is typical of crank sensor (PG's) and it should flash FI code 19....I believe.
Ed, try to get some codes (or lack of) and check back with the guys for more .help.
post #7 of 19 (permalink) Old 03-31-2019, 04:25 PM
Ed, if it craps out on you again, teach it a lesson and just leave it sitting on the side of the road. You have to let a bike know who's boss and that you won't put up with any of its foolishness.
redwing52 and Bvanemon like this.
post #8 of 19 (permalink) Old 03-31-2019, 06:57 PM
Until GL1800s, it is in the Honda manual as a crank position sensor. It was a PG from 1980 to 2000 but it (they) was in a dry location, that might be the difference in terminology. Yes, it would produce a code 19.
If it dies again pull over without turning the switch off, put the sidestand down, it should flash a code if one is present.
redwing52 likes this.
post #9 of 19 (permalink) Old 04-01-2019, 02:41 AM
Terminology is sort of my pet peeve. It has caused me a lot of trouble and confusion. I'm sure you have stories as well. It is bad enough that someone might use different names for the same thing but I have had experiences where they refer to the same item with two different names in the same paragraph. Also, is there such a thing as proof reading any more? Caterpillar has one of the better systems. Most have paper copy manuals so if there is a mistake you are stuck with it. They might or might not even change the issue on future published manuals but no help for those who have manuals with mistakes. I can understand why they can't afford proof readers though. It is because they sell the manuals for such a reasonable price. Cat has online manuals and you buy a subscription. If there is an error they fix it. The next guy who comes in 5 minutes later gets the right info. Ford has that in there Oasis system but only dealers can get it. We rely on the manuals as Gospel. Even a missing slash mark can cause confusion and hours of aggravation but I just don't think any one cares any more. Service like the old days is dead. Can you remember gas for .16 cents a gallon? Wash your windshield pump the gas check air in the tires and check your oil. I feel so lucky to have lived when I did. Those were the days.
post #10 of 19 (permalink) Old 04-01-2019, 06:04 AM
You would have gone crazy working for Honda. I have seen many cases of a part being called one thing in the service manuals, another in the parts catalog and another still in the flat rate manual. It really gets confusing sometimes.
GL1800 Stalls during heavy rain Bigdealwriter Goldwing Technical Forum 12 07-13-2017 04:21 PM
GL1200 Engine Stalls DWG Goldwing Technical Forum 9 11-04-2011 10:00 AM
2001 GL1800 stalls after running-Opinions HondaHank Goldwing Technical Forum 3 04-04-2011 01:56 PM
engine cut out and stalls gumby Goldwing Technical Forum 3 12-26-2009 08:55 PM
