Out of gas......TWICE!!!!!! - Page 2 - Steve Saunders Goldwing Forums
 10Likes
post #11 of 18 (permalink) Old 04-04-2019, 08:40 PM
Originally Posted by van002 View Post
I never rely on the gage or low fuel lights. Comes from being a general aviation pilot I guess, as small aircraft gages are typically considered unreliable. I frequently calculate the mileage and have a high mpg and low mpg figure that I use to determine fuel stops. On the highway, when I hit 150 miles, I need to be in front of a gas pump. Local and slower roads, I use 180 miles. Have never run out that way.
I do the same. The gauge is just a backup. On a long trip I start looking for gas a 200 miles.
post #12 of 18 (permalink) Old 04-05-2019, 05:57 AM
DenverWinger's Avatar
Can't read the trip meter without glasses anymore, but after the fuel needle has been a quarter inch past empty for about 30 miles or so you kinda start seeing the Low Fuel light (if it's a cloudy day or at night). Can't rely on the low fuel light (too dim to see in daytime) so I just consider the 1/4" past empty point a good time to get fuel. That's usually a 5 to 5.5 gal fillup.
One of these days when I have the tupperware off I'll get into the tank and bend the float arm so the gauge reading makes more sense.. Thinking I'll also convert the low fuel thermister to a float (there's a thread on that here or on 'Docs, somewhere).
Of course, the 1100 is (and my other past bikes, too, for that matter) much less ambiguous about low fuel. Its gauge stays on empty a long time, too, but when you're down to reserve there is absolutely no doubt. (Except for one time when I reached down and discovered "That WAS Reserve!")
limpy45 likes this.
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is online now
post #13 of 18 (permalink) Old 04-05-2019, 07:39 AM
Year: 1998
Model: GL1500 SE
None of my bikes before this one had a gas gauge, Mileage is the key. Of coarse on the OLDER bikes you had to do the "switch to reserve" dance at 60 MPH on the highway in traffic! That was always fun and taught you to learn to use the mileage as an indicator.
limpy45 likes this.
Rickf1985 is offline
post #14 of 18 (permalink) Old 04-05-2019, 11:27 AM
bamaTrider's Avatar
Why push it so close to empty in the 1st place? I start looking for gas just below the 1/4 tank mark.
1999 Honda VT1100T Ace Tourer
\'04 GL1800 Goldwing (previous),
and now '04 GL1800 with CSC Cobra trike
bamaTrider is offline
post #15 of 18 (permalink) Old 04-05-2019, 12:23 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
Because we can.............!
Several hundred thousand miles on Gold Wing's and never ran out of fuel yet.
Never any carb issues....!
DBohrer is online now
post #16 of 18 (permalink) Old 04-05-2019, 01:51 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
I've rode my wing for Commuting, more than leisure; typically 70 miles daily.
I had my fuel consumption so perfectly worked out, that I could fill up every 3-days rather than every 2... which I was able to do by Riding the Same Route, at the Same Speed (under 65mph) every day. I'd typically reach the gas station with under 10 miles remaining in the tank. That "extra day" of gas saved me ~4 gas stops a month, or about an Hour of Time... which was the carrot for me.
limpy45 likes this.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #17 of 18 (permalink) Old 04-05-2019, 06:19 PM
I run the fuel level down low so as to get more miles per fillup.
I also carry a 1 gallon leak proof Jerry Can "just in case".
have never run out of gas, have at times topped off at 5.9+ gallons
I use the GPS in "Look Ahead" mode to see how far the next gas opportunity is.
then compare that to the tank reading, which I have calibrated by pouring in exactly 1 gallon of gas to see where the fuel gauge reads.
for everyday riding? I fill it up when I get home.
What is the Forum Index?
Download it here:
post #18 of 18 (permalink) Old 04-09-2019, 01:04 PM
CWN
CWN's Avatar
Year: Pro 1500
Model: 43 years winging it
1200 Calif model only for comparison.
CWN is offline
Arkansas look twice ad. woodbutcher General Motorcycle Discussion Forum 23 12-18-2009 09:03 PM
Tire Recommendations GL1100I Fully Loaded...TWICE!LOL olered67 General Motorcycle Discussion Forum 19 12-01-2009 08:37 PM
1978 gl1000 stopped on interstate twice today Gas Cap??? morriscatt Goldwing Technical Forum 2 09-18-2008 09:28 AM
Baby with Tumor born twice!! D-Rod Miscellaneous Forum 0 06-09-2008 10:37 AM
Double the work, But twice the fun!! Ghost Rider 2 General Motorcycle Discussion Forum 17 06-05-2007 07:36 PM
