GL1500 Cruise Control/Compressor - Page 2 - Steve Saunders Goldwing Forums
 14Likes
post #11 of 15 (permalink) Old 04-04-2019, 08:22 AM
Originally Posted by DenverWinger View Post
Last year I hit the "Mute" button for the stereo on the 1500, it immediately worked really good. Took half a can of CRC Spray and wearing out both thumbs working at that switch to get the stereo unmuted. Cruise button wasn't so stubborn, I got a "Cruise On" light in maybe 15 minutes. I just leave it on now.
Left switch cluster needs to come apart, though. Hazard flasher switch not working right either, after the rest of the can of CRC spray and really sore thumbs I gave up on it...
Two more clicks and you would have had it!
Straydog, limpy45 and DenverWinger like this.
redwing52 is offline
post #12 of 15 (permalink) Old 04-05-2019, 07:46 AM
NevadaDave's Avatar
Originally Posted by jimduffenais View Post
Try shooting some contact cleaner in behind the cruise button. Sometimes its a bit sticky or dirty. Can also try small amount of wd40 too but id try the contact cleaner first. Let it sit overnight ..then try the cruise button...see if it comes on.
For what its worth...once its on..just leave it on. Less wear and tear on the button.
I would agree - my cruise activation switch is intermittent, so I just leave it permanently "ON". I did have an issue with my kill switch causing the bike to die/not restart. I finally pulled the switch apart and cleaned the dickens out of it and now it works perfectly. I think some minor disassembly and contact cleaner will benefit your situation.
Straydog and limpy45 like this.
Whatever good you see in me is the result of what Jesus has done in my life.
NevadaDave is offline
post #13 of 15 (permalink) Old 04-09-2019, 07:17 PM Thread Starter
mpicke's Avatar
Model: GL1500
Thanks to all, I will try to cycle the cruise control switches then as suggest just leave it on.
limpy45 likes this.
Traveling on, if I'm not here then I must be gone. Live long and prosper.
mpicke is offline
post #14 of 15 (permalink) Old 05-03-2019, 08:41 PM Thread Starter
mpicke's Avatar
Model: GL1500
Problem did turn out to be dirt on the switch contacts. Cycled the switches a number of times and the cruise control engaged. Lack of use on my part.
Thanks to all for the advise.
limpy45 likes this.
mpicke is offline
post #15 of 15 (permalink) Old 05-03-2019, 09:11 PM
jimduffenais's Avatar
Year: 1990
Model: GL1500
Good stuff...give it a good lubrication..in and out a bunch more times..then push it in and leave it there. I take the same approach to the kill switch. I use it sparingly...we have to turn off the key anyway..why where out a switch if we dont have too.
limpy45 likes this.
jimduffenais is offline
Cruise control fix if Cruise on Light bulb burned out rgmr250 Goldwing Technical Forum 15 05-08-2016 02:51 PM
Is the 92 SE starter/cruise control different from the non-SE control chas Goldwing Technical Forum 6 11-23-2014 06:41 PM
GL1500 Air compressor & cruise control enelson2047 Goldwing Technical Forum 13 05-09-2012 09:47 AM
cruise and compressor elements ralroder Goldwing Technical Forum 6 05-26-2008 07:29 PM
GL1500 Cruise Control and Emissions control equipment IanB Goldwing Technical Forum 6 08-22-2006 05:04 AM
