gl1000 clutch lifter spring. - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 04-05-2019, 10:17 AM Thread Starter
dingdong's Avatar
Model: 93 Gl1500 / 76 Gl1000
1976 Gl1000. Was going in to adjust clutch cable, removed the cover and discovered the the lifter return spring laying loose in the housing. Hmmm? What might the symptoms be with this spring not connected?
Tom
Black 93 1500 Aspy
Yellow 76 1000
Black Cherry 04 Rune
"I've now been in 57 states? I think one left to go?" B. O.
dingdong is online now
post #2 of 3 (permalink) Old 04-05-2019, 10:36 AM
It probably wouldn't do anything other than keep the lever from returning all the way.
post #3 of 3 (permalink) Old 04-05-2019, 12:20 PM Thread Starter
dingdong's Avatar
That's kinda what I figured too.
Tom
Black 93 1500 Aspy
Yellow 76 1000
clutch lifter rod rod626 Goldwing Technical Forum 6 05-06-2011 03:26 PM
Lifter Cover Gasket gl1000 tigre2007 Goldwing Technical Forum 4 11-15-2009 08:42 AM
Clutch lifter cover removal GL1100 2wheelsbettern4 Goldwing Technical Forum 3 09-23-2009 09:55 PM
spring spring spring chskbak General Motorcycle Discussion Forum 15 04-07-2007 11:05 PM
Lifter noise Wrenchman Goldwing Technical Forum 3 12-28-2006 08:13 PM
