90 GL1500 Carb. Jetting Question - Steve Saunders Goldwing Forums
 3Likes
  • 2 Post By DaveO430
  • 1 Post By justwingnit
post #1 of 6 (permalink) Old 04-05-2019, 05:00 PM Thread Starter
I think I was wrong once!
justwingnit's Avatar
Year: 1990
Make: GL1500
Model: 1990 GL 1500
My 1090 GL1500 got to the point I was afraid to drive it,
It would not idle (could not turn idle adjuster, it was seized) on take offs I had to raise the rpm's real high and almost red line the thing to get it to take off from a stop, when I was slowing down and down shifting the engine would dye out.
I took the carbs off and found the accelerator pump was not working and when i got into the float bowls the idle jets were almost plugged up!
I un-seized the Idle adjuster, I got the accelerator pump working, but when I pulled the jets out I busted one, so I ordered a rebuild kit off e-bay.
Jets in side my carbs. are 158 mains and 60 idle the kit I bought has 155 and 158 mains along with 50 and 60 idle jets, I live in Chicago area and 99% of my ridding is at this altitude.
Why do they sell the 155 and 50's in same kit and (should I?) or (I should!) just put the 158 and 60's back into the carbs right??
Thanks for your help.
Larry
L8r
Larry
1990 GL 1500 just got her 3/8/16
1986 GL1200A Aspencade, from 6/1/12 to 3/1/2016 have rode over 28,000 miles on her.
1982 KZ 1100 may have put 10000 miles on it in 10 years
Multiple Yamaha XS 750 & XS 850 One had a vetter fairing, bags and trunk
Honda CB400 Drove from Chicago to Tulsa Ok in 1984
Honda CB250 Enduro loved it from street to dirt and back again all the time.
YZ 250 never raced but rode alot, First bike ever was a mini bike with a Brigs engine.
justwingnit is offline
post #2 of 6 (permalink) Old 04-05-2019, 05:27 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Did you get your carburetor rebuild kit from this guy.....?
https://www.randakks.com/randakks-ow...rhaul-kit.html
If not you should have.....!
DBohrer is offline
post #3 of 6 (permalink) Old 04-05-2019, 06:34 PM
You should gauge those jets to see if they are really the size they are supposed to be.
post #4 of 6 (permalink) Old 04-06-2019, 10:31 AM
snowmoer's Avatar
Model: 1988 GL 1500, 2012 GL1800, 1977 GL1000 2012 KLR 650
The 155 main and 50 idle jet were for the 88-89 carbs. The recall changed the idle jet to 55 to get rid if the stumble at takeoff. You want the 158 and 60 in your carb for the 1990.
Also make sure the carbs are balanced. This makes a big difference on how the bike will run also.
Dan
AMA Life
2012 GL 1800 Level 3
1988 GL 1500
1977 GL 1000
2012 KLR 650
snowmoer is online now
post #5 of 6 (permalink) Old 04-06-2019, 07:55 PM
MaynardGKrebbs's Avatar
Year: 2004
Make: honda
Model: gl1800
put the rich ones in, both idle and main. with the crap we get for gas with the 10% ethanol, you are already 5% lean.
MGK
MaynardGKrebbs is offline
post #6 of 6 (permalink) Old 04-08-2019, 06:48 PM Thread Starter
Year: 1990
Make: GL1500
Model: 1990 GL 1500
Thanks, I reassembled them with OEM sizes today.
DaveO430 likes this.
L8r
Larry
GL12 jetting question whodat90 Goldwing Technical Forum 4 01-20-2019 06:55 PM
Jetting question on 76Gl 1000 TYoungone Goldwing Technical Forum 8 07-28-2014 07:30 PM
jetting for gl1100 with single carb manifold and solex 30/31 pict JJB Altered Induction 2 07-23-2011 12:00 PM
carb jetting and airpressure instructorpilot Goldwing Technical Forum 1 11-27-2006 12:04 PM
Carb jetting GL1000 newtscoots Goldwing Technical Forum 9 03-28-2006 11:45 PM
