CB Interference from EC LED headlights - Page 3 - Steve Saunders Goldwing Forums
 9Likes
post #21 of 33 (permalink) Old 04-19-2019, 06:36 AM
tamathumper's Avatar
Year: 2003
Model: GL1800A
Pretty much the same set I bought, back when I was getting RFI from a USB charger in the truck. Helped some, the closer I got it to the end of the cable the better, and I had to loop the cable through it twice.
AZgl1800 likes this.
tamathumper is offline
post #22 of 33 (permalink) Old 04-20-2019, 06:16 AM
DJ99Wing's Avatar
Year: 2005, 1999, 1986, 1973
Model: GL1800, GL1500_SE now with Hannigan Trike kit, GL1200 Aspencade, CB750-K3
Thank you Both, Great Info... Just ordered a set to see if I can improve the issue
Just to be clear by "the end of the cable the better" you are referring to being closer to the LED light or other such device being powered and not closer to the (battery) power source.
DJ99Wing is offline
post #23 of 33 (permalink) Old 04-20-2019, 10:38 AM
Year: 2010
Typically those are placed on the item you wish to reduce the noise on.
In other words, on the cb antenna coax, and the cb power and control lines.
What they do in simple terms, is soak up the offending radio frequency from the outside of the coax and hopefully block it from getting into the receiver
Sent from my XT1254 using Tapatalk
guyval is offline
post #24 of 33 (permalink) Old 04-20-2019, 01:59 PM
Year: 2003
Model: GL1800A
By "end of the cable" I meant the end of any cable closest to, and going into the device suffering the interference.
post #25 of 33 (permalink) Old 04-20-2019, 03:31 PM
don't try to put a toroid on the antenna coax.
that is not where the problem is anyway, and it will kink the coax....
Unless, you have the split half type toroids.....
and those are only used on extremely high power transmitters anyway.
the KiloWatt types.
post #26 of 33 (permalink) Old 04-21-2019, 05:11 AM
Year: 2003
Model: GL1800A
Yes, these are the split toroids.
Out of curiosity, I went out to the garage and turned the key on, then selected CB. I live in a very remote area, so there's nobody likely to be transmitting, on any channel.
During my cross-country trip last year I had already replaced the low beams with ECs and the driving lights with SoCalMotoGear PathFinder LEDs, and I apparently had the squelch set to 6 (that's what it was set at, and I haven't used the CB since somewhere in New Mexico). Now with the addition of having the high beams replaced with ECs the CB is full static at 6, intermittent static at 7, and silent at 8.
Not a perfect example of the scientific method, I know, but it's what I got.
post #27 of 33 (permalink) Old 04-24-2019, 11:16 AM Thread Starter
dadztoy's Avatar
Year: 2009
Model: 2009 Silver GL1800 ABS
Sounds about what mine are like now with all the ferrite chokes in place... Still working on a solution for FRS radio on the bike but away from home for a while now... Have the audio interfaced into headset successfully but still have to integrate the mic audio... If I'm successful, I'll post the mod...
4 wheels moves the body
2 wheels moves the soul
GL1800 HPNAM9
Double Darkside - BT-45
dadztoy is online now
post #28 of 33 (permalink) Old 04-24-2019, 12:05 PM
Year: 2003
Model: GL1800A
I'm thinking the Sena SR10 is the ticket for FRS / GMRS, or is it just for CB for some reason?
post #29 of 33 (permalink) Old 04-24-2019, 02:46 PM Thread Starter
dadztoy's Avatar
Year: 2009
I want to be able to use FRS and hand a unit to a buddy and have him plug it into his 5 pin DIN headset and use it with his existing setup... Think it's doable, at least on my bike as I am using electret mic's... Not sure if dynamic's will work, but will continue on with experiment when I return home in a few weeks... Been working out details in my head for a while - getting close to trying it on my bike...
AZgl1800 and tamathumper like this.
GL1800 HPNAM9
post #30 of 33 (permalink) Old 04-24-2019, 11:51 PM
ka4yqi's Avatar
Year: 2012
Model: Goldwing GL1800 Trike
Dadztoy, I watching to see what you end up with. Sounds like using the ferrite chokes has really helped. I ran the 50 watts equ leds on the lower lights on the gl1500 se and never picked any addition noises. My 1800 trike had a J&M single fiberglass antenna on the rear thats is for am/fm cb with a box under the seat to run to the am/fn and one lead to the cb. I dont have a cb on the 2012 goldwing. So I saving my dpllar for one.
Thanks for what you and the other guys are doing and I will be watching.
Steve
ka4yqi is offline
R/R Audio Interference GL1100A fgh Goldwing Technical Forum 2 11-30-2012 12:49 PM
Reverse = headlights, out of Reverse = no headlights ? Chromo General Motorcycle Discussion Forum 8 07-31-2012 10:33 PM
Audio interference from lighter plug....iPhone 4s odies Goldwing Technical Forum 1 03-12-2012 06:05 AM
Portable CB radio interference Q General Motorcycle Discussion Forum 6 01-02-2009 01:44 PM
Radio Interference ChickenWing1200 Goldwing Technical Forum 0 06-17-2008 04:31 PM
