Darkside Question - Page 3 - Steve Saunders Goldwing Forums
 3Likes
post #21 of 37 (permalink) Old 04-12-2019, 11:03 AM
Year: 2008
And a great work space to go with it.....that is a work space isn't it?
Charlie
flylow is offline
post #22 of 37 (permalink) Old 04-12-2019, 04:46 PM Thread Starter
New Sidecar guy
Year: 1998
Model: SE/Hannigan Sidecar
Yeah, it becomes a work space when I back the pick up out....
odinjunior is offline
post #23 of 37 (permalink) Old 04-14-2019, 08:54 AM
Jimnwendyuk's Avatar
Model: SE1500
Did you settle on a tire? I run a 155 16 R van tire. I've done 40,000 miles and it's time for a new one. The present tire makes the gearing higher than stock which means slipping the clutch to move away. The clutch has stood the abuse but ideally a smaller circumference would be easier.
What is your sidecar? Look's very stylish from the rear.
Keep you knees in the breeze...
Jimnwendyuk is offline
post #24 of 37 (permalink) Old 04-15-2019, 04:04 PM Thread Starter
New Sidecar guy
Year: 1998
OK my Austone Taxi tire is ordered.
post #25 of 37 (permalink) Old 04-16-2019, 12:01 PM
Model: GL1100 Interstate
I have spent several months researching this subject and I was just about to pull the trigger on the Austone when I found out it was being discontinued. They have some, but the future of that tire is bleak. I did not want to fall in love with a tire I could not replace, so I went with the Nokian C Line Cargo 185/75R16C D/8PR. It has a load rating of 1800lbs. I figure it should hold up to anything I throw at it and be stiff enough to eliminate the wallow that some car tires can have. I have read of others running this or similar tires and having good luck with it. Price was not too bad at $131 and free shipping from tires-easy.com
oldmopars is offline
post #26 of 37 (permalink) Old 04-18-2019, 06:13 PM
IDRC's Avatar
Model: 88 GL 1500
Look at simple tire for a 175/75R16 (oem size) or a 185/75R16 (Austone size).
They will be a van/truck type tire,
IDRC is offline
post #27 of 37 (permalink) Old 04-22-2019, 03:59 PM
Year: 1978, 1995
Make: Honda Goldwing
Model: GL1000, GL1500 both with Sidecars
Red face Sidecar Tires
Originally Posted by odinjunior View Post
We just acquired a 98 Gl/Sidecar rig. It's going to need tires and soon. What is the current choice for the rear? A search here brought up a recommendation for the Austone Taxi tire.
I have a 95 GL1500 with a Hannigan astro 2+2 and get excellent mileage and handling using a Goodyear Assurance 175/60 R16 on the rear. I get 21K on this rear tire and I am on my 3rd one. This tire is about 3/4 inch smaller in diameter than the original tire and changes the Rev's about 300 RPM higher in all gears. No effect on gas mileage since the car tire has much lower rolling resistance. I like the higher Revs, since at about 35MPH I was always sort of between gears and the smaller tire fixed that.
FYI I also use a Continental 130/70-18 M/C Bias ply ContiGO on the front. This is a rear tire that is mounted backwards since it's on the front. It has about 1/8 inch deeper tread than a front and I get about 11-12K on these.
Gerry
VGH3241 is offline
post #28 of 37 (permalink) Old 04-22-2019, 05:24 PM
Gerry
How do you figure the larger footprint has less rolling resistance?
post #29 of 37 (permalink) Old 04-22-2019, 05:37 PM
It's the new math which is beyond me and by the look of it you.
Ken Bergen is online now
post #30 of 37 (permalink) Old 04-22-2019, 06:09 PM
tamathumper's Avatar
Year: 2003
Model: GL1800A
Might be true. A "wider" contact patch has lower rolling resistance than a "longer" one.
tamathumper is offline
GL1100 darkside question mayo Goldwing Technical Forum 18 09-05-2012 10:55 PM
Another Double Darkside Question Andy Cote General Motorcycle Discussion Forum 1 08-18-2011 08:22 PM
Darkside Question....not tires cired99 Goldwing Technical Forum 9 10-30-2010 08:20 PM
