Hunting idle, dead spot off idle - Page 3 - Steve Saunders Goldwing Forums
 6Likes
post #21 of 26 (permalink) Old 04-17-2019, 10:58 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Originally Posted by Jerry Burns View Post
The hose I'm talking about starts on the top of the left cylinder head and runs to the carb's if I remember right. If you pull the left side lower cover you will see it. I changed mine with the same hose from my old motor that I had, but that hose has to make a U turn and was made with that bend in it. I would buy OEM if I could find a new one. It's a good place to start looking for your Idle surge.
Similarly, on the right side of the bike (center cylinder, about an inch above the valve cover) is a screw... It's typically removed/replaced with a brass spigot when connecting a Mercury Carb Balancer.
Anyhow, if that screw (or the capped spigot) is missing/loose, then you'll get a vacuum leak there too.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #22 of 26 (permalink) Old 04-17-2019, 11:04 AM
Honda Guru
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
[QUOTE=ALEX BERECZKY;5835687]Gotta dis-agree on this one... A leak like this is above the carb, hence will not at all affect the fuel/air mixture that subsequently occurs downstream, after the air has passed through the carb. An air leak above the carb will only By-pass the air filter... which is bad, because you'd be drawing dirty air into the carb.
Sometimes ya gotta learn the hard way....
A guy comes into my shop, says he just bought his 1500 a couple of months ago. Had a chance to ride his buddy's 1500 and it accelerated MUCH better. So I test rode his bike and sure enough it was flat off idle and wouldn't accelerate till it was above 3k rpm. Long story made short... I found holes drilled in the top of the air box. 3 holes each the size of a silver dollar (if you remember those LOL).
Taped the holes and.... fixed.
Same airleak above the carb line caused the flat spot and poor acceleration and poor throttle response.
RambozoClown likes this.
Ray
88 GL1500
rayworx is offline
post #23 of 26 (permalink) Old 04-18-2019, 06:10 PM
IDRC's Avatar
Model: 88 GL 1500
I think you need to do the accelerator pump modification. That was the repair for the 88-89 hesitation issue.
The procedure was at one time in the archives here.
You can also google it.
There are 2 bypass ports that have to be plugged. It’s not a difficult job, but you must remove the carbs to do it.
You also need to add a .05 mm washer under the main needle, this greatly helps on the low speed needle to main needle transition.
IDRC is offline
post #24 of 26 (permalink) Old 04-18-2019, 09:40 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
There are 2 bypass ports that have to be plugged. Itís not a difficult job, but you must remove the carbs to do it.
Obviously you didn't look at the attachments in post # 4. Its there.....!!!!!!
BTW.....It was only for the 1988 (not 1989).....!!!
DBohrer is online now
post #25 of 26 (permalink) Old 08-10-2019, 03:52 PM Thread Starter
WALTSTAR's Avatar
Model: 1988 GL 1500
Ok, so I have installed the sensor and waited a week before starting the wing.....Voila! problem solved. Thank you for the guidance, Guru's! I did the 6 and then 4 degree trigger wheel about 17 years ago. The bike now screams up to redline immediately... Thanks again!
DaveO430 and DBohrer like this.
WALTSTAR is offline
post #26 of 26 (permalink) Old 08-11-2019, 05:56 PM
brownfoxx1's Avatar
Make: gl-1500
Model: Interstate with roadsmith trike HT1500 kit
next time you have the air cleaner off break a tooth pick in half and put it in the lower idle jet (brass tube).
brownfoxx1 is offline
weird flat spot off idle gl1500 Transam1 Goldwing Technical Forum 3 06-01-2013 07:43 AM
GL1500 dead spot between 2200 and 2400rpm 2006GL1800 Goldwing Technical Forum 4 09-16-2012 08:42 AM
GL1500 flat spot off idle chirojerry Goldwing Technical Forum 10 05-30-2010 10:20 AM
89 gl1500 off idle flat spot 55b33 Goldwing Technical Forum 19 10-17-2009 06:56 PM
Dead Spot - 08' 1800GL txgoldwing1 Goldwing Technical Forum 3 08-27-2009 05:09 PM
