Hunting idle, dead spot off idle - Page 4 - Steve Saunders Goldwing Forums
 6Likes
post #31 of 31 (permalink) Old 09-07-2019, 07:28 AM
It aint rocket science
DriverRider's Avatar
Model: The best
So the problem appeared after a winter layover. You are a long time owner and presume riding less as we age. I suspect the older unused fuel left in the bike finally caught up to you and fouled the idle jets.
Like Ivory soap 99.7% of the time running problems on a 1500 are carburetion/emission control related. The first thing an owner does is crank up the idle and maybe jack with the sync screws on an engine that won't run. An engine surge is then produced if the engine is not constantly being fed the metered fuel from the carb(s) due to a blockage. The limited fuel flow in the carb circuit collects in a pocket then gets sucked into the engine causing the surge and repeats over and over.
Remove the air filter and with a little carb clean spray dribble it down into each carb throat. The idle RPM will go way up on a faulty carb/cylinder bank.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
weird flat spot off idle gl1500 Transam1 Goldwing Technical Forum 3 06-01-2013 07:43 AM
GL1500 dead spot between 2200 and 2400rpm 2006GL1800 Goldwing Technical Forum 4 09-16-2012 08:42 AM
GL1500 flat spot off idle chirojerry Goldwing Technical Forum 10 05-30-2010 10:20 AM
89 gl1500 off idle flat spot 55b33 Goldwing Technical Forum 19 10-17-2009 06:56 PM
Dead Spot - 08' 1800GL txgoldwing1 Goldwing Technical Forum 3 08-27-2009 05:09 PM
