Neutral sensor repair on a 1500 - Page 3 - Steve Saunders Goldwing Forums
 11Likes
post #21 of 22 (permalink) Old 04-21-2019, 06:44 PM
I don't think it has anything to do with the side-stand. When you pull in the clutch handle, do you hear a click?
If so, are the two wires plugged into the switch?
If not, why not?
post #22 of 22 (permalink) Old 04-22-2019, 12:38 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
Ben, When you pull the clutch lever all the way inward, pull slightly upward on the lever. Does it activate the micro switch....?? It might.
I know of a case where it works......!!
Bellboy40 likes this.
DBohrer is offline
Neutral/Gear Position Sensor GL1200 Markos Goldwing Technical Forum 3 02-16-2019 07:37 PM
GL1500 neutral light sensor switch test tyrefitter Goldwing Technical Forum 18 10-25-2015 10:13 AM
GL1500 Neutral sensor-cable to be replaced flw Goldwing Technical Forum 4 09-14-2011 06:32 PM
Crank Case Sensor (ckp sensor) GL1800 Russell Thibault Goldwing Technical Forum 3 07-10-2010 12:24 PM
