80' 1100 Rear Brake Master Cylinder C clip not holding - Steve Saunders Goldwing Forums
 10Likes
post #1 of 15 (permalink) Old 04-15-2019, 10:17 AM Thread Starter
Year: 1980
Model: GL1100
My rear master cylinder came apart, C clip popped out. So I bought a rebuild kit, cleaned up the master and installed all the rebuild parts. I cleaned the grove where the C clip rides with a dremel brass wire wheel. Reassembled everything, bleed the system and it was all working fine. Test drove 25 miles or so and no problem.
Then yesterday the C clip popped out again (the rebuild kit included a new C clip which I used).
So clearly the lip on the master that holds the C clip is too corroded to hold properly. Unfortunately the 80-82 rear brake master cylinder is a hard to find part. I seem to have two options (dismissing the option of waiting until the part lands in my lap):
1 - disassemble the current master and use the dremel with a grinding wheel to cut the grove deeper/sharper.
2 - adapt a master from another year/model to fit (description of one method found on this site at: https://www.goldwingfacts.com/forums...r-upgrade.html
Anyone have a similar problem with the C clip falling out? Is my option 1 even plausible?
dbnewton is offline
post #2 of 15 (permalink) Old 04-15-2019, 11:00 AM
rayjoe's Avatar
goldwing
Find someone with a metal lathe and a small boring bar to clean up the groove.
Using a dremel will probably make it worse.
Rayjoe
bobalou and RambozoClown like this.
rayjoe is offline
post #3 of 15 (permalink) Old 04-15-2019, 02:00 PM
a dab of JB weld will hold that clip
NASR 12 in Galena, IL
post #4 of 15 (permalink) Old 04-15-2019, 02:44 PM
The clip is directional.
The sharp side goes in the direction of thrust which in this case is down or out.
bobalou and JamesPal like this.
Ken Bergen is offline
post #5 of 15 (permalink) Old 04-15-2019, 03:27 PM
If all else fails drill a hole above the clip and put a screw in both sides to hold the clip in place.
bobalou likes this.
post #6 of 15 (permalink) Old 04-15-2019, 06:15 PM
Duct tape that thang!
bobalou likes this.
post #7 of 15 (permalink) Old 04-15-2019, 10:07 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
This is important. Also, make sure the clip is fully seated. It only takes a speck of crud to keep clip from seating. I would suggest getting a scribe with a hooked end and run it around the circumference.
bobalou likes this.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #8 of 15 (permalink) Old 04-18-2019, 07:24 PM
Year: 1992
Model: Aspencade 1500
Isn't that a wire type C clip?
If so replacing it with a real snap ring or better yet a spiral lock will probably hold better in your worn grove. There are also push in retaining rings with teeth that grip the bore and don't even require a groove.
As mentioned above the real fix is to clean up the groove in a mill or lathe. Round profile for a wire C clip, square profile for a snap ring or spiral lock.
Go to McMaster Carr and search "Internal Retaining Rings".
bobalou likes this.
RambozoClown is offline
post #9 of 15 (permalink) Old 04-18-2019, 08:37 PM Thread Starter
Year: 1980
Model: GL1100
When I removed the MC I decided to install the C clip (it is actually a snap ring). What I discovered was it was quite loose in it's grove as if it was too small.
So that led me to suspect there was something wrong with the snap ring. Quick experiment showed it was not a good spring in that it did not return to it's same diameter after being narrowed with the snap ring pliers.
Decided it was time for a new ring. The new ring seemed to hold it's shape after deformed to install and importantly fits tightly into it's grove.
So far it's holding. Only about 2 miles on a test drive but lots of braking. Maybe I just got an inproperly tempered snap ring in the kit??
bobalou likes this.
dbnewton is offline
post #10 of 15 (permalink) Old 04-19-2019, 10:37 AM
Official "Cheeky Plonker"
chilidawg's Avatar
Year: 1980-81-82-83
Model: GL1100STDASPENSTATE
Or one that was just 39 years old!
Age, gets to us all in the end, don't it?
bobalou likes this.
chilidawg is offline
Brake master cylinder and clutch master cylinder. Makedon Goldwing Technical Forum 4 11-15-2018 08:33 PM
1200 rear shocks not holding air f5guy Goldwing Technical Forum 8 05-18-2014 11:32 PM
'80 GL 1100 Standard Rear Master Cylinder Needed galen avery For Sale/Wanted Forum 9 10-11-2013 11:18 AM
Rear shocks not holding air, GL1200LTD jobe05 Goldwing Technical Forum 6 11-13-2011 04:11 PM
Rear brake master cylinder seals for '80 GL1100i chetvaldes Goldwing Technical Forum 3 02-07-2009 12:00 AM
