stuck brake caliper piston - Steve Saunders Goldwing Forums
 5Likes
  • 1 Post By rayjoe
  • 1 Post By DaveO430
  • 1 Post By Wilcoy02
  • 2 Post By Unicorn Wing
post #1 of 7 (permalink) Old 04-15-2019, 06:28 PM Thread Starter
bobalou's Avatar
Model: 1100
ok it is off a 1000. tis bike was supposed to be someones fake build and sold as a build. It is stripped of all bits we consider normal. no tach no speedo nada. A new friend brought it to me as it was only running on three pistons and number 3 carb was receiving almost no fuel. Carbs were sent out for rebuild by the bikes builder which I say BS too. They are now at Pistol Petes for a real cleaning. Brake lines weather checked and cracked, new ones on order. Rear Brake was n to even touched as it was rusted to non operable. Half of the caliper is cleaned up nice! Problem at this point I have a stuck piston in the other half. am looking for ideas to get this piston out.
Thank y'all for already answering on other folks posts gotta love getting answers when no one has to respond to the question that was already asked.
They are all perfect
Last samuri
bobalou is offline
post #2 of 7 (permalink) Old 04-15-2019, 06:59 PM
All I can suggest is lots of penetrating oil and put a clamp on the piston to push it in. That has worked for me on a couple of occasions. Sometimes it can take a couple of days.
post #3 of 7 (permalink) Old 04-15-2019, 07:01 PM
rayjoe's Avatar
goldwing
In the past I have had good luck using an air compressor. BE CAREFUL NOT TO GET BODY PARTS (fingers) IN THE WAY. I stick a thin piece of wood in between to cushion the caliper when the piston flys out.
Rayjoe
BadMonk's1200 likes this.
rayjoe is offline
post #4 of 7 (permalink) Old 04-15-2019, 07:11 PM
Those opposed piston calipers can be fun. Put it back together and clamp the already free piston in so it won't move then connect the brake line and pump it out. Pretty unlikely normal air pressure will move it.
limpy45 likes this.
post #5 of 7 (permalink) Old 04-15-2019, 09:44 PM
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
What has always worked is to put the caliper back together.
Put a piece of wood or something for a stop of the pistons.
Connect a grease gun up to the line in to the caliper.
Pump until both pistons are out.
rayjoe likes this.
Wilcoy02 is offline
post #6 of 7 (permalink) Old 04-16-2019, 10:18 AM
Year: 1983
Model: Aspencade
I made a piston puller from rubber corks bought at Ace hardware. A bolt, some washers and nuts to squeeze the cork and expand it inside the piston. I had to use some emery cloth around it for grip but they popped right out after I had tried all the other methods.
Bike...and Dennis and rayjoe like this.
Unicorn Wing is online now
post #7 of 7 (permalink) Old 04-16-2019, 08:33 PM
Official "Cheeky Plonker"
chilidawg's Avatar
Year: 1980-81-82-83
Model: GL1100STDASPENSTATE
I've never had to do it but I heard that a grease gun works well and fits right on to the bleed nipple.
I do know though that a lever action gun puts out up to 9000 psi and a pistol grip 6000, so that ought to do it!
chilidawg is offline
Videos. Have a locked or dragging brake. How to remove a stuck brake caliper piston Quick Cal Goldwing Technical Forum 2 05-04-2015 10:37 PM
One out of two stuck caliper piston Quick Cal Goldwing Technical Forum 14 05-03-2015 11:22 PM
80 GL1100 front brake piston stuck crupiea Goldwing Technical Forum 6 10-27-2011 06:33 PM
Stuck Caliper Piston morriscatt Goldwing Technical Forum 18 05-24-2009 11:49 AM
Wanted: 1100 Rear brake caliper single piston DarinS For Sale/Wanted Forum 1 03-31-2007 03:08 PM
