Throttle Spring Help - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 04-17-2019, 01:18 PM Thread Starter
Year: 1987
Model: GL1200 Interstate
When balancing the carbs, it was obvious that the throttle spring (on carb #3) wasn't right. It looks like the end/hook of the spring, closest to the back end of the bike, hooks onto the linkage bracket (see first pic). But I can't see where or how the other end, closest to the front of the bike, should go (see second pic). Maybe the spring is broken...don't know. Bike is a '87 1200.
BadMonk's1200 is offline
post #2 of 6 (permalink) Old 04-17-2019, 01:27 PM
The inner end hooks on a stub under the throttle shaft, about 1/2 way around CCW from where it is in the first picture.
post #3 of 6 (permalink) Old 04-17-2019, 01:31 PM Thread Starter
Year: 1987
Thanks, Dave. My eyes didn't see the stub so I'll check again...maybe get better glasses too.
post #4 of 6 (permalink) Old 04-17-2019, 01:53 PM
CWN
CWN's Avatar
Year: Pro 1500
Model: 43 years winging it
Here.
CWN is offline
post #5 of 6 (permalink) Old 04-17-2019, 01:58 PM Thread Starter
Year: 1987
Much obliged, CWN. I was not focusing in the correct spot but now I think I know where to look.
post #6 of 6 (permalink) Old 04-17-2019, 02:00 PM Thread Starter
Year: 1987
Bingo! Thank guys.
Throttle spring tension galaxyhunter Goldwing Technical Forum 3 05-27-2011 07:42 PM
Throttle spring worn out? bkfass Goldwing Technical Forum 7 09-25-2009 11:40 PM
Main throttle return spring FinallygotmyGoldwing Goldwing Technical Forum 2 02-27-2008 10:56 AM
spring spring spring chskbak General Motorcycle Discussion Forum 15 04-07-2007 11:05 PM
GL1000 - throttle link / spring hirsty Goldwing Technical Forum 6 10-14-2005 09:10 AM
