#4 Carb Is Off The Chart - Steve Saunders Goldwing Forums
 9Likes
post #1 of 29 (permalink) Old 04-17-2019, 05:11 PM Thread Starter
Year: 1987
Model: GL1200 Interstate
Had the carbs apart over the winter for cleaning. End of winter, I ran and balanced them with no problems. Rode the bike three or four times and it ran well. Last week, however, it idled rough as the day wore on. I assumed it was the idle mix screws and figured to re-tune the carbs today. In the process, I found the throttle spring was detached and #3 plug wire was in bad shape. Fixed all that - spring, plug wire and idle mix - hooked up the CarbTune to balance them and...#4 carb consistently moves the mercury (?) to the top of the scale. It pegs there and does not come down to earth.
I switched the hoses around to make sure it's not the manometer, tubes, etc. It's not any of that. The #4 carb runs to the top of the scale no matter what configuration is used.
It's strange, to me, because it had balanced several weeks ago with no issues. Now, it's unreadable. What's going on with #4 please?
BadMonk's1200 is offline
post #2 of 29 (permalink) Old 04-17-2019, 05:38 PM
Official "Cheeky Plonker"
chilidawg's Avatar
Year: 1980-81-82-83
Model: GL1100STDASPENSTATE
I'm more used to gauges than a manometer so are you saying that you have a positive pressure at the intake of #4 instead of a vacuum, or do you mean it just stays at zero psig?
chilidawg is offline
post #3 of 29 (permalink) Old 04-17-2019, 05:43 PM Thread Starter
Year: 1987
It's not zero, so yes it's positive pressure. In terms of a dial gauge like a speedometer, it's pegged at 120 mph...if you catch my drift.
post #4 of 29 (permalink) Old 04-17-2019, 06:05 PM
chilidawg's Avatar
Year: 1980-81-82-83
I kinda hoped you wouldn't say that, because I can't think of any other way for that to be highly positive than a problem with the intake valve on that cylinder. If you take the pipe off of that intake, can you feel anything coming out?
Sucks I know, but maybe some others will chime in with some better and less expensive ideas.
post #5 of 29 (permalink) Old 04-17-2019, 06:08 PM Thread Starter
Year: 1987
Might explain why that one spark plug suddenly decided to run very rich, just outta the blue.
post #6 of 29 (permalink) Old 04-17-2019, 06:10 PM
chilidawg's Avatar
Year: 1980-81-82-83
post #7 of 29 (permalink) Old 04-17-2019, 06:19 PM Thread Starter
Year: 1987
Sorry, not following what you mean. What 'pipe' from the 'intake'?
post #8 of 29 (permalink) Old 04-17-2019, 06:33 PM
He's referring to the exhaust head pipes.
post #9 of 29 (permalink) Old 04-17-2019, 06:42 PM Thread Starter
Year: 1987
Thanks Dennis. That's what I thought but wasn't sure.
Need to do a compression test before doing much else. Reading doesn't turn up any info on why one gauge would spike like that.
post #10 of 29 (permalink) Old 04-17-2019, 06:43 PM
#4 is the base carb on a 1200, all others synch off it. Turn the base idle screw in to get the vacuum to come down, the idle will go up, then start adjusting the others to match #4.
siouxindian likes this.
Wiring Chart For 1966 Honda 90 dean General Motorcycle Discussion Forum 18 11-17-2008 11:30 AM
Spark plug cross reference chart suks2bu37 Goldwing Technical Forum 4 02-29-2008 09:17 PM
Official Canadian Temperature Conversion Chart.. retiredintime Fun Forum 5 02-28-2008 07:45 AM
Panasonic type III stereo wiring chart Jocke Goldwing Technical Forum 2 06-12-2007 11:16 PM
HOSPITAL CHART BLOOPERS Putt N along Fun Forum 4 11-25-2005 03:58 PM
