2000 GL1500 smoking after start up - Steve Saunders Goldwing Forums
 3Likes
post #1 of 16 (permalink) Old 04-21-2019, 10:39 AM Thread Starter
Jedake's Avatar
Model: GL1500 SE
Question 2000 GL1500 smoking after start up
Finally took my bike out of storage, had to change the battery and got it started. Once it was started, there was smoke coming from the vents in the ferring and then up through the handle bars. Let it run for a few minutes, shut it off and made sure it was on the main stand. Started it up a few times since and no smoke. I was heading out for the first ride of the season, letting the bike warm up and started smoking again. I will assume a seal but not 100% sure.
Any ideas and if so, how to repair?
Thanks in advance
Jedake
Jedake is offline
post #2 of 16 (permalink) Old 04-21-2019, 10:45 AM
Normal,
don't get too worried about it.
it has sat a long time, and oil seeped into places it normally won't be.
sounds like you left it on the side stand?
if out of the fairing, it is water droplets from hoses that shrunk when they got cold.
as soon as the engine warms up, they will be just fine.....
but, you might want to open up the plastic and cinch down on the hose clamps...
I read very recently that removing a clamp, and taking the thread spacer out, and grinding off about 3/16th inch from its' length is helpful....
that spacer prevents you from over tightening the clamps and ruining the hose.
but, after 30 years, the hoses are getting a bit old.
NASR 12 in Galena, IL
post #3 of 16 (permalink) Old 04-21-2019, 10:54 AM Thread Starter
Jedake's Avatar
Model: GL1500 SE
Thank you, It was stored on the main stand.
It smells like something is burning (almost like rubber, I may be mistaken).
It starts with smoke coming out of the fairing and then a lot more up through the handle.
You are saying if I let it run it will dissipate?
Jedake is offline
post #4 of 16 (permalink) Old 04-21-2019, 10:56 AM
Pure Texas's Avatar
Make: Goldwing
Normal,kinda embarrassing at times but this flat motor has done that since 1975
Never had it come out of the fairing though.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #5 of 16 (permalink) Old 04-21-2019, 10:58 AM Thread Starter
Jedake's Avatar
Model: GL1500 SE
thanks,
I will let it run for a bit then and see.
Jedake is offline
post #6 of 16 (permalink) Old 04-21-2019, 11:55 AM
DenverWinger's Avatar
Mine leaks a little coolant if sitting for a long while, after warmed up once no more leak. Might be coolant you smell....
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is offline
post #7 of 16 (permalink) Old 04-21-2019, 12:11 PM Thread Starter
Jedake's Avatar
Model: GL1500 SE
thank you
Jedake is offline
post #8 of 16 (permalink) Old 04-21-2019, 12:26 PM
If you smell something burning and see smoke, well that sounds more serious to me.
Where are you located? You should have that in your profile so someone close by might be able to drop in and check it out for you.
It might be that mice have built a nest against the exhaust header. Depending on their building materials there may be a potential for a real fire. Or, yes, it could be oil from the shift shaft seal dripping onto the exhaust.
flylow, John J and tamathumper like this.
post #9 of 16 (permalink) Old 04-21-2019, 12:38 PM Thread Starter
Jedake's Avatar
Model: GL1500 SE
Restarted it, let it run for a bit...no smoke...took it for a little jaunt....no smoke. Still not sure about it then.
Located in Smiths Falls, Ontario, Canada. Anyone near??
Jedake is offline
post #10 of 16 (permalink) Old 04-21-2019, 02:56 PM
Maybe whatever it was burned off.
If it doesn't come back in the next couple of years, you'll probably be okay.
smoking at start up firechiefsmith200 Goldwing Technical Forum 11 03-17-2011 09:59 PM
GL1500 hard to start! Except after a hard start...? ThFireman Goldwing Technical Forum 48 10-26-2009 08:40 PM
Smoking after antifreeze change KeithM Goldwing Technical Forum 5 04-09-2009 09:27 PM
smoking on start up thecub Goldwing Technical Forum 10 07-14-2005 05:14 PM
Smoking on start-up Shooter Goldwing Technical Forum 17 09-16-2004 03:45 AM
