What might I expect? - Page 3 - Steve Saunders Goldwing Forums
 12Likes
post #21 of 33 (permalink) Old 04-25-2019, 11:52 PM
JohnnyD's Avatar
Year: 1984
Model: GL1200 Standard
Originally Posted by odinjunior View Post
Everyone says that but I have yet to see any one show proof.
You need proof? Run the engine with the old belts until one fails. Your proof will be your blown engine. Or spend a weekend and get it straight, or pay a guy. Rubber in tires AND belts are safe for 7-10 years. Miles will reduce these numbers. Period. It’s like gravity.
Thanks, JD
1984 Goldwing Standard
JohnnyD is offline
post #22 of 33 (permalink) Old 04-26-2019, 01:04 AM
JohnnyD's Avatar
Year: 1984
Originally Posted by John J View Post
With regard to the belts I have seen many posts over the years on this forum and others, mainly from new owners to a bike, asking whether the belts should be changed as the mileage is low but the bike is old. For me, the answer is always the same...change the belts. When I've had a new to me bike I figured the peace of mind of knowing the belts are new is far better than trying to convince myself they don't need doing yet.
Well said. Given we are talking GL1200 or 1500s, these bikes are now OLD. Honda engineers setting mileage numbers for maintenance or replacement were not considering maintenance decades later.
I bought my GL1200 in 2008 with only 14K miles on it. Regardless of miles, the bike was then 24 years old. So I immediately changed the radiator hoses. I would have also changed the belts, but the original owner kept good paperwork and I found a receipt for timing belt service in 2006.
In 2016, after my stator was dead for a year, and I was tired of charging my bike after every cruise, I pulled the engine, did the stator and among other service and cleaning, of course I installed new timing belts. I’m thinking $15 each at Napa for Gates belts. Of course the belts I replaced looked new.
So my ‘84 Standard today with only 26,500 miles has had at least 3 sets of timing belts. That comes to changing on average every 8800 miles. It’s more the years than the miles, unless you’re Dennis and have 290K miles on your Wing.
I’m changing tires this week, not because the tread is bald. It’s because the DOT manufacturers date is 2012. I don’t wear out my tires. That’s hard to do when you have 4 street bikes. I’m not going highway speeds with tires 7+ years old. Thanks for reading. JD
Thanks, JD
JohnnyD is offline
post #23 of 33 (permalink) Old 04-26-2019, 07:39 AM
joe in calif's Avatar
02 & 05 what? Gl1800s don't have belts.
I should said 92 & 95 SORRY
A NEW START ON 1/20/2017
joe in calif is offline
post #24 of 33 (permalink) Old 04-26-2019, 06:57 PM
Official "Cheeky Plonker"
chilidawg's Avatar
Year: 1980-81-82-83
Model: GL1100STDASPENSTATE
Really, I didn't know they'd gotten rid of that headache, so what do these here new fangled 1800's have now?
A chain? Or maybe something really bulletproof, like push-rods, or desmodromic shafts perhaps?
I really would like to know!
Because I never had an ounce of worry when I had either of those.
chilidawg is offline
post #25 of 33 (permalink) Old 04-26-2019, 07:21 PM
They have chains. Same on most Honda cars these days with few problems. The only ones I ever saw have a problem had a fram oil filter. Just like the early days of Honda when using a fram would cause the cam bearing surfaces to gaul.
post #26 of 33 (permalink) Old 04-26-2019, 09:58 PM
chilidawg's Avatar
Year: 1980-81-82-83
Well I guess the chain won the battle then, but all those Triumphs, Norton's and BSA's where definitely fun bikes, as where the later Ducati's.
Not to mention the fact that, (well I guess I am.) Major US manufacturers would make V8 racing engines with push-rods, specifically for the Indianapolis 500 mile race. Right up until the early 90's.
Gotta be a good reason for that, ain't there??
post #27 of 33 (permalink) Old 04-27-2019, 01:28 AM
Year: 1985
Model: Interstate
Tires have a 10 year expiration date
Sprocketrocket55 is offline
post #28 of 33 (permalink) Old 04-27-2019, 01:43 AM
Where did you read/hear that?
post #29 of 33 (permalink) Old 04-27-2019, 01:47 AM
Year: 1985
Model: Interstate
It's actually 6 years, max is is 10
https://www.popularmechanics.com/car...ires-15408787/
post #30 of 33 (permalink) Old 04-27-2019, 07:01 PM
Mike Myers's Avatar
Year: 84 GL 1200
Model: 84 Aspencade
I thought 5 yrs from DOT stamp on tires? rubber things? a blow out on a car/truck tire is a PROBLEM... a blowout from dried out tires on a bike is CATASTROPHIC. ... i wud think. im trying to figure out how to mark the timing belt covers so the next owner knows that the belts were changed @... month/yr. when i get brave enough to change the belts, if i get brave enough to change the belts. getting the radiator cap off to get radiator out ... might be a challenge. i read it is a thumb and one finger deal and i have.... all thumbs. unless im playing cards... then i have "a hand.... like a foot" anyway, engraver on top of belt guard, primitive but functional.
Mike Myers is offline
Might anyone have a spring removal tool I might borrow? JamesDTaylorSTL Goldwing Technical Forum 12 08-10-2013 03:01 PM
Front brake locks on GL1100, when you least expect it. chilidawg Goldwing Technical Forum 25 11-29-2009 12:36 PM
what to expect? don_s Goldwing Technical Forum 8 09-13-2008 08:04 PM
how many miles to expect on a gl1100 engine? atowley Goldwing Technical Forum 25 03-11-2007 09:01 PM
After long downtime, what should I expect DaveH Goldwing Technical Forum 6 12-03-2005 10:07 AM
