95 gl1500 Saddle big center marking light - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 04-21-2019, 02:27 PM Thread Starter
Model: 1995 Gl SE
Looking to change those bulbs also to LED does anybody remember the bulb size number that is in there I believe there’s two ?
Gary Neppell is offline
post #2 of 6 (permalink) Old 04-21-2019, 05:18 PM
Andy Cote's Avatar
Are you talking about the red light below the license plate that lines up with the brake lights in each pannier?
If so, that originally was a reflector. There were two aftermarket replacements made. One is taillight only which should be 1156 bulbs. The other is brake and taillight which would be 1157.
DARKSIDE #1500
2015 Goldwing - basic black
Ham Extra Class AC1R
Andy Cote is offline
post #3 of 6 (permalink) Old 04-22-2019, 12:47 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
If it functions as a running light only, it will be a 1156 bulb..
If it functions as a running light and a brake light, it will be a 1157 bulb.
Choose the bulb number according to how your light functions....!
DBohrer is online now
post #4 of 6 (permalink) Old 04-22-2019, 03:37 PM Thread Starter
Model: 1995 Gl SE
What threw me off was the signal bulb in the rear was a 1073 and the running light brake light bulb the two filament bulb was a 2057
post #5 of 6 (permalink) Old 04-22-2019, 04:09 PM
DBohrer's Avatar
The 1157 and 2057 are interchangeable. But the 1157 is slightly brighter (not much).
post #6 of 6 (permalink) Old 04-24-2019, 08:39 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
If you have a cruise control system problem after this led upgrade, you may want to read the following thread.
https://www.goldwingfacts.com/forums...em-solved.html
Erdeniz Umman is online now
Marking a Decade monkeytrucker Miscellaneous Forum 8 06-03-2014 07:40 AM
Opinions on marking rear tire valve stem, the first time flw General Motorcycle Discussion Forum 8 10-04-2010 12:45 AM
