Rear drive clicking at slow speed. After changing tire '89 GL1500 - Page 2 - Steve Saunders Goldwing Forums
 5Likes
post #11 of 17 (permalink) Old 04-26-2019, 12:02 AM
Originally Posted by steve60usa View Post
I did lube the splines where the hub with the pins mate with the splines on the final drive. When it is cool, it doesnít make noise. After a few miles, I can hear it when I am going super slow. I donít hear anything at faster speeds. I guess I have to pull the rear wheel again. As you all know, it isnít a picnic doing that. I use the method where you pivot the hitch and all the trunks up out of the way. I used the stethoscope with it on the center stand and in gear running and it isnít the brakes. It also isnít as noticeable unless you are riding it.
How about this CAREFULLY. Put the bike on the centerstand while it is acting up. Start the engine and duplicate the speed just spinning the wheel. Does it make noise freewheeling like that? Apply some load by applying brake. Does it click then? That brings up another question. Driving down the road with the bike clicking apply slight brake. Does it stop clicking when you apply brake. Apply brake and use some throttle to overcome the brake. Any better. Don't overlook what gl mentioned. If the final drive is not entered it might click where the spline meets. That is any easy try. Loosen 4 bolts a few turns and sping the wheel or start the engine to spin the wheel. Tighten back up. Like Dave B says, Easy stuff first.
DBohrer likes this.
redwing52 is offline
post #12 of 17 (permalink) Old 04-26-2019, 01:44 AM
I've heard wheel bearings "click".
And they would probably stay quiet until the grease warms up a bit.
post #13 of 17 (permalink) Old 04-26-2019, 01:57 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
How many miles on the bike?
At around 100k the Rubber Dampeners (inside the rear hub) wear out, which leads to Slop between the mating Aluminum Blocks (which themselves wear out too)... Could be that slop results in noise, as the drive-line oscillates between the ends of that new big mating gap in parts.
John J likes this.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #14 of 17 (permalink) Old 04-26-2019, 09:47 PM Thread Starter
It has 71000 miles on it. I am definitely going to try to loosen the bolts where the rear drive bolts to the swing arm. If that has the ability to rotate a little, bring out of alignment would be the noise I am hearing. When I spin the rear wheel by hand, it is quiet and smooth.
steve60usa is offline
post #15 of 17 (permalink) Old 04-28-2019, 12:24 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
At 71,000 miles rubber dampers are not the issue...............!
DBohrer is offline
post #16 of 17 (permalink) Old 04-28-2019, 02:23 PM
rayjoe's Avatar
goldwing
Since no one has mentioned it, have you checked for rocks or a nail head in your tire?
Rayjoe
rayjoe is offline
post #17 of 17 (permalink) Old 04-28-2019, 04:27 PM
dadztoy's Avatar
Year: 2009
Model: 2009 Silver GL1800 ABS
Originally Posted by MICK MACK View Post
which driveshaft splines? the ones in the U joint or the ones on the Final Drive? the pins? cant see how they would click? they are a pretty solid fit in their holes and the pins are chrome plated and have to be HARD . I took mine apart and they were dry dry dry with rust in the holes. never enough time to do it right the FIRST TIME.... but ALWAYS time to do IT AGAIN . when everything is done... there is ALWAYS ONE MORE THING TO DO.
In the final drive at the opposite end of the drive shaft from universals- replaced several final drives of friends bikes due to lack of lubrication over an extended period of time... Last one I did required drive shaft and rear end replacement due to excessive wear... Honda's Moly Paste will work fine back there... I would lube it at every tire change or at least every other tire change on a 1500...
Les
4 wheels moves the body
2 wheels moves the soul
GL1800 HPNAM9
Double Darkside - BT-45
dadztoy is offline
89 1500 idle surge after #60 slow jet installed? 1sweetlover Goldwing Technical Forum 16 05-19-2014 09:53 AM
Spare part lying around after changing GL1100 rear tire? jshfchtr Goldwing Technical Forum 11 03-05-2012 04:45 AM
Slow, Slow, Slow LUV2WING Miscellaneous Forum 25 01-25-2009 10:16 PM
Want Final Drive and Drive Flange/Rear wheel for 88/89 GL1500 4evermetric For Sale/Wanted Forum 0 09-20-2007 04:58 PM
Wanted: GL1500 Final Drive, 88 or 89 GL1500 Drive Flange, GL1500 Driveshaft tuntrep For Sale/Wanted Forum 0 07-09-2006 08:06 AM
