Left Heated Grip Coming On HOT! - Page 2 - Steve Saunders Goldwing Forums
post #11 of 14 (permalink) Old 05-10-2019, 07:18 PM
It would only be the switch if BOTH grips wouldn't turn off.
post #12 of 14 (permalink) Old 05-10-2019, 10:22 PM
NASR 12 in Galena, IL
post #13 of 14 (permalink) Old 05-11-2019, 04:18 AM
tamathumper's Avatar
Year: 2003
Model: GL1800A
Pretty sure it's already online, at http://justwings.com/uploads/HEATED_...THERMOSTAT.pdf
AZgl1800 likes this.
tamathumper is offline
post #14 of 14 (permalink) Old 05-22-2019, 07:17 PM Thread Starter
OldRider2's Avatar
Year: 2001
Make: Honda GL1800
Model: GL1800/GL1000
Hello all, just a quick update. I found the two wires from the left grip under the handlebar so I removed the little metal plate that holds the wires, brake line and such. I unplugged the wires and did a quick continuity check and it was just a few ohms as I remember. One of the wires had some darkened spots on both terminal ends inside the clear plastic connector cover. The dark spots looked more like old and discolored plastic but I suppose they could have been burn spots where the metal plate was touching them? Anyway I put it back together and have taken a couple of rides and both grips turn on and off and appear to be working normal.
2001 GL1800
1977 GL1000
OldRider2 is offline
Looking for replament part for GL1800 heated handle grip grip winger1 Goldwing Technical Forum 4 11-09-2013 05:54 AM
gl1100 with a full vetter HOT HOT HOT timbrains Goldwing Technical Forum 7 09-03-2010 10:30 AM
Hot Hot Hot !!!! Right winger General Motorcycle Discussion Forum 30 08-13-2010 06:39 AM
Heated Grip Kit for under your hand grips Dusty Boots General Motorcycle Discussion Forum 8 04-16-2009 06:07 AM
GL1100i Hot Hot Hot! roytoy1 Goldwing Technical Forum 49 08-02-2006 10:22 AM
