Muffler Hanger Bolt Flange '85 1200 A - Steve Saunders Goldwing Forums
  • 1 Post By DaveO430
post #1 of 3 (permalink) Old 05-10-2019, 12:16 PM Thread Starter
Impersonating a mechanic
PAPete's Avatar
Year: 1982 & 1985
The exhaust on this bike was lowered last fall to get to the starter, and when I re-assembled it, I could not get the left side hanger bolt to seat so that it could be screwed in. Here's the problem:
The first pic shows the rider footstep, with the hanger-bolt hole in the lower right.
Second pic is obvious.
Third pic is a closeup of the bolthole with the flange dimly visible behind it.
And the last pic is taken from above and shows the (surprising) problem: The flange that is welded to the muffler is actually two flat pieces! The near side is bent downward and covers part of the bolthole, so the bolt can't get in to reach the threads.
I suppose I could heat up the flange and attempt to bend up the portion that's bent down. Or I could use a Dremel tool and cut off the bent part of it.
Do you think it's rideable as is? The right side hanger bolt is securely in place.
I'm looking for other suggestions and comments. Thanks.
NOTE:This work won't be done until August: Life intrudes once again on motorcycle life.
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
post #2 of 3 (permalink) Old 05-10-2019, 02:37 PM
Do you not have a hammer?
post #3 of 3 (permalink) Old 05-10-2019, 03:30 PM Thread Starter
PAPete's Avatar
Year: 1982 & 1985
Look closely at the last picture, Dave. Only half the flange is bent over. ALL the way over. It (the flange) is as if you had two slices of bread together and the one nearest you was folded in half, toward you. So I don't think a hammer would help, but I have to say: "If I had a hammer, I'd hammer in the mor - or -ning....."
Thanks for the reply, though.
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
F/S 84-85 1200 flange gear CWN For Sale/Wanted Forum 0 06-12-2017 11:05 PM
GL 1500 EZ Harley Muffler Hanger txtriathlete Goldwing Technical Forum 7 07-22-2012 06:12 PM
Front engine hanger bolt on 1986 GL1200/ question slowpoke Goldwing Technical Forum 1 10-02-2011 06:53 PM
Coat Hanger Swaggerman Fun Forum 2 09-24-2006 12:27 PM
Front engine hanger bolt Uncledeadly Goldwing Technical Forum 4 03-09-2006 10:32 PM
