Giving up "Bells" 1200GL limited edition - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 05-10-2019, 03:33 PM Thread Starter
hunter27h's Avatar
I have reached that stage in life when I have to give up some of my toys, and one of them is my Limited edition. I have not ridden it in probably 5 years and that is sad, but it's life. I am in the process of cleaning servicing etc, and discovered that the turn signals do not flash, all of the lights come on properly, including the cornering lights, but no flash. I have the tank cover off and for the life of me I can't find the flasher. In the past, I did extensive work on this bike and have had everything off of it including the fairing, but if someone can just help with the location of the flasher before I pull out the last of my hair.
Thanks
Ben
hunter27h
"fair winds, and following seas"
"an old Goldwing, for an old guy"
1 1985 LTD "Bells"(1) "Bells" is now a trike (triwing classic)
1989 Goldwing 1500/6 "Glory" 148,000 like new miles
1991 Gold Wing SE Anniversary edition 39000 miles #647, "truly the fastest color"
Ben
hunter27h is offline
post #2 of 9 (permalink) Old 05-10-2019, 04:03 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
DBohrer is online now
post #3 of 9 (permalink) Old 05-10-2019, 04:15 PM Thread Starter
hunter27h's Avatar
Thanks...hoping one of the other Limited edition drivers have encountered this, as a lot of the 'stuff" is different on these jewels.
hunter27h
Ben
post #4 of 9 (permalink) Old 05-10-2019, 05:37 PM
rayjoe's Avatar
goldwing
If it's not the flasher unit, check to see if the bulb sockets have rusted or the switch needs cleaning. A bad ground might cause this also.
Rayjoe
rayjoe is offline
post #5 of 9 (permalink) Old 05-10-2019, 06:10 PM
DBohrer's Avatar
Are you looking for item # 27 in this diagram....??
https://www.partzilla.com/catalog/ho...ctifier-sensor
post #6 of 9 (permalink) Old 05-10-2019, 06:56 PM Thread Starter
hunter27h's Avatar
Found the flasher, located on the frame, just forward of the rear tire..
hunter27h
Ben
post #7 of 9 (permalink) Old 05-10-2019, 07:16 PM
Rednaxs60's Avatar
To confirm it is the flasher unit, you can swap it for the 4 way flasher. It is the relay on the left side of the bracket. If you need to replace the flasher relay it is still available from Honda, but you need to order P/N 38301-MBW-D21. Make sure it has a 3 pin connection.
Ernest
Rednaxs60 is offline
post #8 of 9 (permalink) Old 05-11-2019, 09:55 PM Thread Starter
hunter27h's Avatar
Yep, I finally found it...but thanks!
hunter27h
Ben
post #9 of 9 (permalink) Old 05-11-2019, 09:57 PM Thread Starter
hunter27h's Avatar
Ordered flasher last night, in the meantime, just cleaning, changing fluids, since old "Bells" has been sitting idle for a while.
hunter27h
Ben
For Sale 1985 Limited Edition Full Face G/W Helmet Hawggy For Sale/Wanted Forum 9 11-11-2009 05:51 PM
Gremlin bells, schremlin bells ob1quixote General Motorcycle Discussion Forum 14 12-09-2008 07:15 AM
1200 Limited Edition Fuel Filter MrGolfnut Goldwing Technical Forum 4 09-21-2006 07:36 PM
GL1200 Limited Edition.... daveinozbikes Goldwing Technical Forum 10 08-01-2005 11:12 AM
GL1200 Limited Edition CB Long Hair Goldwing Technical Forum 4 04-12-2005 12:53 PM
