85 1200 Aspencade: Oil from water pump weep hole - Page 3 - Steve Saunders Goldwing Forums
 13Likes
post #21 of 30 (permalink) Old 05-13-2019, 09:53 PM
Originally Posted by PAPete View Post
According to the procedure for water pump replacement on Goldwing Docs, which I just reviewed, the smaller of the two o-rings ie, the hindmost ring, keeps the oil out, and the larger one keeps water out of the cavity. So your edit is correct.
And I thank you all again for your help. We're heading back to Pennsylvania tomorrow, but will be back to this bike in mid-August.
In the meantime, I'll be looking for o-ring/seal kits, just in case I mashed one (or more), when I replaced the water pump two years ago. I already have new front cover and water pump gaskets. Any suggestions for sources would be welcome Thanks.
Just do not forget to replace the oil pump seal. Get the parts from Honda, don't even think about aftermarket parts for this job.
post #22 of 30 (permalink) Old 05-13-2019, 09:54 PM Thread Starter
Impersonating a mechanic
PAPete's Avatar
Year: 1982 & 1985
I can't explain how I missed that so many times. Except...
...I recently had another birthday.
So Happy Birthday, already!
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
post #23 of 30 (permalink) Old 05-13-2019, 09:56 PM Thread Starter
PAPete's Avatar
Year: 1982 & 1985
OK. Thanks, Dave.
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
post #24 of 30 (permalink) Old 05-13-2019, 10:44 PM
Looks to me like the o-ring (red arrow) is redundant. The oil pump seal and another o-ring at the front of the pump keep oil out of the void.
Edit; thinking on it more, remembering more, that o-ring does also keep oil out of the void.
Getting old is a .....now I forgot what I was going to say!
redwing52 is online now
post #25 of 30 (permalink) Old 05-14-2019, 12:21 AM
Year: 2006
Thanks, Smeden, for the good news and the bad news. The bad news is that I should replace the water pump. I doubt that it has more than 200 miles on it, and they're not cheap. I replaced it in 2016, and this bike really doesn't get ridden very much.
You can also reuse your water pump and see how long it will last .
On my Gl1000 is has worked perfect for at least 8 year since i changed out the oil seal and reused the old water pump . BUT i dont ride that bike much and only locally .IF i was using the bike for long distance riding i would have replaced the water pump .
post #26 of 30 (permalink) Old 05-15-2019, 05:02 PM Thread Starter
PAPete's Avatar
Year: 1982 & 1985
That sounds like a good plan for me. I plan to change the oil seal and some o-rings and see how that goes. While I'll be 80 next year, I'm hoping to stay physically (and mentally) fit enough to ride for a few more years. We'll see how that goes too.
Thanks for your contributions to this post.
AZgl1800 and redwing52 like this.
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
post #27 of 30 (permalink) Old 05-15-2019, 07:00 PM
If you find an issue with the o-ring be it twisted, cut or missing then you might want to decide if you want to replace the oil pump seal. It is a little tricky as you have to drive it in with the lip going against the grain. I always cringe when I have to do this as I tend to have more issues putting them in when I face that type of situation. Of course if there is a stream or washed clean below the seal you have no choice. Just cross your fingers and be careful.
post #28 of 30 (permalink) Old 05-15-2019, 07:04 PM
That oil pump seal should be replaced any time you do a water pump.
Ken Bergen likes this.
post #29 of 30 (permalink) Old 05-16-2019, 12:07 AM
Normally I would agree with Dave. Pete it is your call. Given your age and ability if you feel confident enough changing it might be best. If it shows no signs of leaking it might not be a bad idea to leave well enough alone. It's a judgement call. If I were 80 and saw no indication that the seal is leaking I would leave it alone. Of course I'm just hoping to make it to 80. My riding days are winding down already.
post #30 of 30 (permalink) Old 05-16-2019, 01:28 AM
Year: 2006
Yes , i would do as well.
To PaPete(and others who like to know) ,- the seal is around $3 , nr. 91207-580-003 .
Oil from weep hole under GL1200 water pump Corney Goldwing Technical Forum 20 05-20-2012 03:25 PM
"84 oil leak from water pump weep hole.... groutby Goldwing Technical Forum 13 04-08-2009 09:58 PM
Oil from water pump weep hole HeartAttackBill Goldwing Technical Forum 19 10-18-2008 03:18 PM
Oil Dripping out Water Pump Weep Hole, Which Seal? zowie Goldwing Technical Forum 5 05-08-2007 10:48 AM
water pump/oil out the weep hole on a GL1200 sockeye342 Goldwing Technical Forum 13 09-20-2006 10:57 AM
