GL1500 Tire Change - a Novel Method using car lift - Steve Saunders Goldwing Forums
 3Likes
  • 2 Post By Sprocketrocket55
  • 1 Post By RambozoClown
post #1 of 6 (permalink) Old 05-13-2019, 09:39 AM Thread Starter
I just saw this posted on Facebook and thought the method to be quite novel.
Not everyone has a car lift in their home garage, except maybe DaveO430
Pretty slick, huh?
He still had to remove the left muffler.
  • Robert Taylor It is possible that way, but you still have to lower the mufflers out-of-the-way to get the axle out. I take it you pulled it out from the back!
  • Billy Puckett Only removed the left muffler
post #2 of 6 (permalink) Old 05-13-2019, 11:55 AM
Year: 1985
Model: Interstate
When I use the Hoist at the Honda shop I just slid the motorcycle back on the center stand let the back tire hang out in the air. I suppose you could do the same thing using a trailer
AZgl1800 and DBohrer like this.
Sprocketrocket55 is offline
post #3 of 6 (permalink) Old 05-13-2019, 04:09 PM
Yes I do.
post #4 of 6 (permalink) Old 05-13-2019, 08:11 PM
And it's color coordinated. How nice.
post #5 of 6 (permalink) Old 05-13-2019, 10:19 PM
Year: 1992
Model: Aspencade 1500
It's the only way to fly. I made a couple of beams of 4" steel channel with welded pins to fit my hoist arms, and rubber pads on top. Holds the bike rock solid. You would be hard pressed to push it off, if you wanted to.
Too impatient to paint them at the time. Someday...
CrystalPistol likes this.
RambozoClown is offline
post #6 of 6 (permalink) Old 05-18-2019, 07:06 PM
Year: 78, 86, 02, 03
Make: Honda GW's
Years back when I was on a trip my 1500 ate a rear tire sooner than I expected ( I was having fun, tho. ) and the dealer I stopped at changed the tire just like that. Had never seen it and was a little nervous but it worked well.
OldAge is online now
GL1800 Rear Tire Change method AZgl1800 Goldwing Technical Forum 22 01-06-2016 11:30 PM
using a car tire on a oldwing MTHillyer Goldwing Technical Forum 22 10-20-2014 10:47 AM
Does Bag Lift Rear Tire Change Technique Work for 1990? StereoSteveo Goldwing Technical Forum 15 10-14-2012 07:15 PM
The new Harlequin Novel--2012 Version PurplePirate Fun Forum 3 07-14-2012 04:38 AM
Using radial car tires on a GL1500 AZgl1800 General Motorcycle Discussion Forum 88 07-28-2011 11:29 AM
