How to choose right clutch disks? - Steve Saunders Goldwing Forums
post #1 of 21 (permalink) Old 05-13-2019, 12:35 PM Thread Starter
Model: GL1500 98 SE
Question How to choose right clutch disks?
I would like to replace the Clutch disks, but can not determine whitch clutch system could be in my GL.
As you can see in attached files, I found that in GL1500 98 SE could be two differentent systems. One wtih disks A, B and C.
Another A and B disks only.
How to determine, whitch one is right for me?
My bike Goldwing 1500 SE 98
Thank you in advance.
Pokeristas is offline
post #2 of 21 (permalink) Old 05-13-2019, 12:48 PM
That is usually determined by the bike's serial number. A dealer might know what the cut off number is. Do you have any dealers in Lithuania?
If not, you can post the number here and I can make a couple of calls.
post #3 of 21 (permalink) Old 05-13-2019, 02:27 PM Thread Starter
Model: GL1500 98 SE
The number of engine: SC22E-3004602
post #4 of 21 (permalink) Old 05-13-2019, 03:12 PM
Year: 1992
Model: Aspencade 1500
If you have it apart you can ID the discs by these markings.
RambozoClown is offline
post #5 of 21 (permalink) Old 05-13-2019, 07:51 PM
I think I need the actual serial number. Someone correct me if I'm wrong.
post #6 of 21 (permalink) Old 05-14-2019, 04:24 PM
It aint rocket science
DriverRider's Avatar
Model: The best
One fiche is listed for '96 and the other '97-'98. Go with the MZO version for your '98.
ValkyrieRider likes this.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #7 of 21 (permalink) Old 05-14-2019, 06:32 PM
If you look at the overview fiche for the '98 1500, you'll see two listings for "CLUTCH". Both of those sub fiche are shown.
With a serial number, a helpful parts guy should be able to say which one applies to this particular bike.
post #8 of 21 (permalink) Old 05-15-2019, 06:56 PM
Who the heck cares?
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
The VIN number determines the correct part number. Very rarely does the engine number play a part in determining what part to use. Bike... and Dennis are correct
Ray
88 GL1500
rayworx is offline
post #9 of 21 (permalink) Old 05-16-2019, 11:12 AM
Model: '98 Valkyrie
why, are they worn out? usually good to about 300k miles.
'97 to '00 clutch discs were upgraded as a result of the higher HP Valkyrie and fit all yr GL1500s. your '98 GW should have the upgraded disks. Easiest just use OEM listed for a valkyrie.
ValkyrieRider is offline
post #10 of 21 (permalink) Old 05-16-2019, 11:46 AM Thread Starter
Model: GL1500 98 SE
This is my VIN number: 1HFSC2230WA002116
What color are the GL1200 OEM friction disks? nailgun Goldwing Technical Forum 2 05-08-2011 08:08 AM
Front Wheel Disks GL1100 mjmike Goldwing Technical Forum 3 04-20-2011 03:30 PM
Torque specs for 1500 brake disks jlbc212 Goldwing Technical Forum 1 03-26-2011 11:06 AM
Anyone use sisal disks? TominDallas General Motorcycle Discussion Forum 5 12-23-2010 02:49 PM
Changing the Friction Disks of the clutch fer-kat-97 Goldwing Technical Forum 11 08-04-2007 01:28 AM
