Rear Diif oil change - Steve Saunders Goldwing Forums
  • 1 Post By DBohrer
post #1 of 4 (permalink) Old 05-14-2019, 08:57 PM Thread Starter
BSims66173's Avatar
Year: 1996
Model: GL1500SE
Hello everyone. Haven't been on in a while. I have a 1996 1500SE that I have owned since 06. I rode it quite a lot the first few years I had it but as age creeps up on me and Pearl we both got to the point we weren't running as good as we did in our younger days. I have several health issues that prevented me from riding for a few years. I have breathing problems, Rheumatoid Arthritis (aggressive type) back problems with nerve damage going to my legs but hey, I wake up everyday and enjoy what the man above gives me. Anyway with all my problems, Pearl has sat for the most part. The carbs got to the point the bike would not stay running so I pulled the carbs and sent them off for rebuild and put them back on and bike ran ok but not like it should. That was in 2015 I think. Didn't ride it much then. In 2017 I took it to a local shade tree motorcycle mech recommended by a very good Honda mech and let him rebuild the carbs. Got it back from him and still wasn't right. Had an awful stumble when first starting off and idle was surging. between the two rebuilds I had spent over a thousand dollars and still couldn't ride her. Well after some new medicines, new arthritis treatments I am back to the point I can ride some. Started researching on what it takes to build the 1500 carbs and decided to try myself. I bought me another set of carbs from a 98 of ebay, got a kit from Randakk and tore into her. Once I got her back together and hit the starter she has run better than she has since I have had her. I even impressed myself which I have never done, but she runs like a dream. Now to my day today. I have never changed the rear diff oil since I have had the bike so today was the day. Pulled the drain plug and out came fairly clean looking oil. I was expecting more oil to drain out. Only got about an ounce and a half to two ounces out. My thoughts was the diff was low. Book says 4.7 ounces so I replace drain plug and go to fill with 2 oz syringe but only could get about 1.75 oz back in before it started running out. My question is did I not do it right or is the book wrong? I think I will go for a short ride and change it again this time with a through flushing. Bike was on center stand which has diff a little high, could some of the oil have stayed in the diff at the lowest point? Just don't want kill my diff because of low oil. Anyway sorry for the long post. I really enjoy reading all the post and a big thank you to all who answer and explain problems people like me have. Very very informative site. Now that I have Pearl up and running I am sure I will be asking for more advice to issues that I may have.
Barry
Barry Sims
BSims66173 is offline
post #2 of 4 (permalink) Old 05-14-2019, 09:35 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
Final Drive
If you removed the drain plug while on the center stand that would empty the final drive. if you filled it until it started running back out the filler hole, then it would be full.
Barry
AZgl1800 likes this.
DBohrer is online now
post #3 of 4 (permalink) Old 05-15-2019, 08:29 AM
joe in calif's Avatar
https://goldwingdocs.com/forum/viewt...p?f=14&t=10535
A NEW START ON 1/20/2017
joe in calif is offline
post #4 of 4 (permalink) Old 05-15-2019, 02:14 PM Thread Starter
BSims66173's Avatar
Year: 1996
Model: GL1500SE
Joe in Calif, that was the post that I went by to change it. Didn't do the hair dryer because the temp was around 85 when I changed it. Also didn't flush it out but let it drain for over an hour.
DBohrer, Yes I filled it up until it ran out the fill hole. Thinking I must have filled it to fast, waited about five minutes thinking it would drain down some. Tried adding more and it just ran out the fill hole also.
Barry Sims
What oil for a oil change leggman Goldwing Technical Forum 14 07-04-2011 06:32 PM
Amount of oil for GL 1800 for oil + filter change? hondarod Goldwing Technical Forum 5 08-02-2009 08:20 PM
Questioning using MMO in oil before an oil change. Richardrwg Goldwing Technical Forum 4 06-18-2009 12:26 PM
The Book Says Don't Change the Oil(first change) til 4,000 miles instead of 600miles? gixxerbill Goldwing Technical Forum 3 06-25-2007 04:06 AM
