How do new alternators measure up? - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 17 (permalink) Old 05-25-2019, 07:36 AM
yeah
I think the RPMs were a factor in the alternator giving up the ghost.
also, the Suburban has Rear Air and we keep it on COLD and high fan for the dogs...
and NASR12 was fun!
post #12 of 17 (permalink) Old 05-25-2019, 08:17 AM Thread Starter
jlaframboise's Avatar
Model: GL1500A
Originally Posted by MaynardGKrebbs View Post
Not sure what Surbuban fuel mileage has to do with it, but thanks for the info.
Yeah, we should have one of the mods spank him for being off topic ;-)
AZgl1800 likes this.
jlaframboise is offline
post #13 of 17 (permalink) Old 05-25-2019, 08:36 AM Thread Starter
Model: GL1500A
The alternator on a GL1500 or 1800 is pretty well enclosed and subject to more heat than on a car that has some air flow in the engine compartment.
Just my theory.
You are a genius Dave! I didn't think of the heat issue. When you add it to the equation, it makes a lot of sense. The high out put alternators are notorious for the high heat they put out. When you figure in the low quality of materials that go into the manufacturing, the components just can't take the heat, nor do they produce the heat that stock alternators do. This would have to be the reason that alternators that are built to OEM specs last longer. Now I need you to invent cooling vents for my side covers.
post #14 of 17 (permalink) Old 05-25-2019, 09:14 AM
Just throw the left side cover away.
post #15 of 17 (permalink) Old 05-25-2019, 12:47 PM
Bill-UK's Avatar
Model: Gl1500 SE
Why not just get it rebuilt locally then you won’t be buying Chinese junk, not sure wether they can increase the output but worth asking, probably a lot cheaper than buying new anyway.
Bill-UK is online now
post #16 of 17 (permalink) Old 05-25-2019, 04:39 PM Thread Starter
Model: GL1500A
I could more than likely rebuild the oem alternator myself but it is running fine right now and I need it for a backup next week. The parts for the lactrical would have taken too long to get here before our trip so I ordered a DB Electrical 90 amp yesterday and put it in today. The parts to rebuild/repair these bad boys come from China. Way back when, I'd see generators get hot enough to sling solder. It doesn't look like mine got that hot but it could have gotten hot enough to melt some electronics.
post #17 of 17 (permalink) Old 05-26-2019, 12:12 AM
it has been several decades now, but I remember seeing alternators and generators that were a mess like that. Solder everywhere, except where it belonged.
and NASR12 was fun!
Where do I measure my windshield? jeffo Goldwing Technical Forum 3 07-12-2009 12:20 PM
How to Measure oil level when installing Progressive Springs? RayandTracy Goldwing Technical Forum 10 04-18-2009 02:55 PM
4mm carb screws that measure 3.8mm., and I chased the hole w/ 4mm tap. PHOENIXMIKE Goldwing Technical Forum 1 04-16-2009 02:22 PM
Dunlop III's -- how to measure wear Cousin Jack Goldwing Technical Forum 10 07-10-2006 05:43 PM
what do the classic wing shocks measure in length? sanfelice Goldwing Technical Forum 4 03-25-2006 07:14 AM
