99 GL1500Se fuel mileage poor - Page 3 - Steve Saunders Goldwing Forums
 8Likes
post #21 of 37 (permalink) Old 06-05-2019, 02:13 PM
Model: '98 Valkyrie
The guy is right about using TCW3 oil but he's way off the mark on gasoline, in the 1970s to mid 80s we found clogged fuel filters often way before the specified 12,000 mile interval, today most gasoline engines never need a fuel filter. When fuel injection became popular they had to improve the fuel quality.
He must work for or have stock in Pennzoil.
all of today's fuel injector vehicles have a fuel filter, certain models have two.
how was he off the mark about gasoline? if u read his posts and testing they just happen to be using pennzoil. any TC-W3 meeting the spec are the same, except for price.
ValkyrieRider is offline
post #22 of 37 (permalink) Old 06-05-2019, 08:51 PM
Son of Bronson
offcenter's Avatar
Model: 76 GL-1000 and a 99 Gl-1500
My '99 1500 gets a steady 42 mpg.
On long highway runs at 65 or 70 mph, it seems to get
just a bit more.
And one of you said that your bike stinks when idling.
So does mine. It always smells rich at idle, but it
runs great and gets good gas mileage.
Another thing...
It would be interesting to know if the guys getting poor
mileage have a large windshield on the bike.
I have my stock windshield cut down fairly short since I am short and wanted to look over the shield.
Aerodynamics can play an big role in fuel mileage at anything over 40 mph or so. A tall windshield has to push a lot more air out of the way.
captdecker likes this.
George in Jersey
99 Gl-1500
76 Gl-1000
It's called a "Dresser".
A bagger is an old lady who lives under a bridge
with her crap in a shopping cart.
offcenter is offline
post #23 of 37 (permalink) Old 06-05-2019, 09:58 PM
Filters that never need to be changed & usually only one built into the fuel pump unit. I was a mechanic most of my working life, I know what was and is now. Gasoline is vastly cleaner than it was 30 years ago.
post #24 of 37 (permalink) Old 06-06-2019, 01:31 AM
just a bit more.
Another thing...
I have already mentioned that my two 1500s had the Tulsa Tall windshields, both about 4 inches above my helmet. 33 mpg is the best they ever got at 70mph, at 35-40mph on an all day jaunt looking at fall colors, I once made 39.5 mpg.
My 1800 now has a Madstad that I can drop down to maybe 8 inches above the dashboard. helps a lot.
post #25 of 37 (permalink) Old 06-06-2019, 07:10 PM
bamaTrider's Avatar
I don’t completely agree on the fairing and windscreen causing lower fuel economy, because the wind is either hitting those, or hitting you. Either way there’s going to be wind drag, and the fairing and shield are much more aerodynamic than you are. I suspect that you have carb mixture issues since turning the idle adjustment screw has no affect on it. If all else fails, then try a K&N air filter. That should lean it out some.
1999 Honda VT1100T Ace Tourer
\'04 GL1800 Goldwing (previous),
and now '04 GL1800 with CSC Cobra trike
bamaTrider is offline
post #26 of 37 (permalink) Old 06-06-2019, 07:15 PM
alamogordo_ed's Avatar
Model: Aspencade
What is TCW3 oil?
1993 Candy Spectra Red Aspencade
Ed Martin
alamogordo_ed is offline
post #27 of 37 (permalink) Old 06-06-2019, 07:38 PM
Model: '98 Valkyrie
Originally Posted by alamogordo_ed View Post
What is TCW3 oil?
http://www.ls1.com/forums/f48/been-testing-oil-91206/
post #28 of 37 (permalink) Old 06-06-2019, 07:40 PM
What is TCW3 oil?
It's 2 stroke outboard oil.
post #29 of 37 (permalink) Old 06-07-2019, 12:37 AM
captdecker's Avatar
Year: 1989 GL1500,2006 GL1800
Make: honda goldwing's
Model: gl1500,GL1800
I have an 89 GL1500 that I changed the trigger wheel too +6 degree(only see 4 degree now) and plugs to iridium one range hot running prem fuel, get a round 50 MPG hwy.
captdecker is offline
post #30 of 37 (permalink) Old 06-07-2019, 09:34 AM
Model: '98 Valkyrie
did your engine ping with regular? original article installing a 6 TW in a GL1500 stated they used regular with zero pinging.
since the GL1500 has zero initial advance at idle putting it at 6 degrees isn't really an issue. The valkyrie has 3 degrees initial, riders using the 4 degree still use regular. FactoryPro.com recommends no more than the 4 degree for the valkyrie.
Hope that helps for more mpg.
