1984 GL1200A Turn Signal relay - Steve Saunders Goldwing Forums
 3Likes
  • 3 Post By DaveO430
post #1 of 5 (permalink) Old 06-14-2019, 07:12 PM Thread Starter
How do I locate and replace the turn signal relay. A step by step would be helpful. Thanks
mikefo is offline
post #2 of 5 (permalink) Old 06-14-2019, 07:22 PM
Dezzr1's Avatar
Year: 85/87
Make: Aspencade/ Interstate
Model: 1985 Aspencade/ 87 Interatate
As far as I remember from my 85 Aspencade there is not a relay like a car.
It is tied in to your speedometer.
I noticed I was not getting a speed reading on my way to work one morning and I also noticed that my blinkers were no longer working.
Bought and installed a new speed sensor and got a speed reading and my blinkers were working again.
Same thing on my interstate, when my speedo cable snapped my blinkers stopped working.
Good luck and sorry if I have given any wrong info.
Dezzr1 is offline
post #3 of 5 (permalink) Old 06-14-2019, 09:43 PM
The turn signal relays, 1 for the turns and 1 for the 4 ways are located to the left and right rear of the air cleaner if I remember right. Don't know off hand which is which but you can switch them and see if it fixes the problem. The speed sensor has nothing to do with the signals not working, only the self cancel function.
post #4 of 5 (permalink) Old 06-15-2019, 11:31 PM
Year: 1985
Model: Interstate
Flow chart for turn signals
Sprocketrocket55 is offline
post #5 of 5 (permalink) Old 06-15-2019, 11:42 PM
Year: 1985
Model: Interstate
Step 4 is checking for ground on the handlebar switch
