O ring oil leak after installing new Alt. - Page 2 - Steve Saunders Goldwing Forums
 2Likes
post #11 of 20 (permalink) Old 06-18-2019, 12:39 AM
the left wing, did not know what the right wing wanted, so it dumped it in the middle.
post #12 of 20 (permalink) Old 06-24-2019, 08:22 PM
Year: 1988
Model: GL1500
Still fighting with this problem. About to pack in this riding season lol. New o ring and still leaks. Torqued to 22 ft/lbs as specs and broke bolt. Took alt off once again and got broken bolt out and got new ones and put in again. leaked again today. So sitting in garage with cardboard under. I am now doubting my abilities to fix it. Do they need to be torqued? What am I missing?
WildWilly018 is offline
post #13 of 20 (permalink) Old 06-24-2019, 08:34 PM
Are you sure the oil isn't leaking through the input seal into the alternator then out?
Ken Bergen is online now
post #14 of 20 (permalink) Old 06-24-2019, 08:58 PM
Year: 1988
Model: GL1500
Not really sure of anything at the moment. I will have to get it off again to see. Nothing leaked before with old alt on. What would cause the input seal to leak it out.
post #15 of 20 (permalink) Old 06-24-2019, 09:05 PM
I'm not familiar with the 1500 PCV system but if the crankcase is running a positive pressure somethings going to give.
post #16 of 20 (permalink) Old 06-25-2019, 07:02 AM Thread Starter
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Have you checked the calibration of your Torque wrench lately. Could it be out of calibration....??
Torquing to specs (when applied correctly) and using the appropriate bolts should not break bolts.....!!
DBohrer is offline
post #17 of 20 (permalink) Old 06-25-2019, 07:09 AM Thread Starter
DBohrer's Avatar
Year: 1967
You posted it just fine. Things went weird when I moved DBohrer's answer from the other post.
Yeah, that DBohrer is causing trouble again.....
DBohrer is offline
post #18 of 20 (permalink) Old 06-25-2019, 04:17 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
22 ft/lbs sounds right, but I'm amazed that your bolt broke while aiming for that spec... I presume that a Higher Torque must have been applied by accident.
Something I've learned is to "Calibrate my hand" prior to using the torque wrench "for real"; Meaning, I use a Vice to clamp onto the end of the torque wrench (or socket that it's holding), and apply force until the Set Torque is attained via the 'Click'... this way I have a rough FEEL for how much effort I should be apply later when installing the whatever into the bike... eg If my "feel" tells me that I'm at or exceeding that amount, then I know to stop and try again; perhaps verifying that the wrench is set correctly.
Also, another recent lesson for me is to use "Hydraulic Assembly Lube" when installing O-rings... It prevents Tearing of the O-rings, as otherwise can occur when assembling stuff in a Dry condition.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #19 of 20 (permalink) Old 06-25-2019, 05:38 PM
Pure Texas's Avatar
Make: Goldwing
I would measure the 2 ends to see if by some chance there’s a difference and question the o ring as to be correct,when you push it in the motor can you tell if it seems tight in the motor or does it try to fall out,it should be snug.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is online now
post #20 of 20 (permalink) Old 06-25-2019, 09:19 PM
CrystalPistol's Avatar
Pinched O-ring will do it, faster if dry. I lube with something.
Originally Posted by tamathumper View Post
How did the response get ahead of the question?
...(Candy Spectra Red )
CrystalPistol is online now
