85 gw interstate stripped - Page 2 - Steve Saunders Goldwing Forums
post #11 of 12 (permalink) Old 06-22-2019, 07:39 PM
There is no headlight relay. Power comes from fuse 8 through a black/red wire to the start switch, to a blue/white wire to the dimmer switch then to either the blue (low beam) or white (high beam) wire to the headlight.
post #12 of 12 (permalink) Old 06-26-2019, 12:50 PM Thread Starter
Model: 1985 interstate
85 gw
Found it bad ground in bundle.. thx for all the advice..
thx gumby
gumby is offline
