'80 gl-100 no spark - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 06-22-2019, 02:52 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
Model: Interstate with roadsmith trike HT1500 kit
'80 gl-100 no spark
it runs if you crank it enough when engine is cold, but don't like to do that.prior owner had a elec fuel pump and a 2 to1 carb installed on it.
brownfoxx1 is offline
post #2 of 8 (permalink) Old 06-22-2019, 05:37 PM
You are saying no spark but then it runs if you crank it long enough. What makes you think no spark? Sounds like the choke isn't working.
post #3 of 8 (permalink) Old 06-22-2019, 05:58 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
bike ran 2 weeks ago when i brought it home. useing craftsman induction timing light.
just tried to start the bike. it tried to start once but didn't. timing light shows no spark.
don't have a choke
verified the timing light works on another vehicle
post #4 of 8 (permalink) Old 06-22-2019, 06:20 PM
don't have a choke
It came with a choke. Check the spark with a spark plug or something else you can put in the plug connector and hold close to a ground point.
post #5 of 8 (permalink) Old 06-22-2019, 07:10 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
my mistake. it runs if you turn the gas on. one lever on each side???? why
post #6 of 8 (permalink) Old 06-22-2019, 07:41 PM
One lever on each side of what? There is the petcock on the left side of the tank.
post #7 of 8 (permalink) Old 06-22-2019, 08:08 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
this one with the 2 to 1 carb see red lever behind fuel pump.square unit is elec fuel pump
post #8 of 8 (permalink) Old 06-22-2019, 09:51 PM
I see. Looks like it has a single carb conversion. And who knows what that valve is about?
