Gl1800 a4 rear shock - Page 2 - Steve Saunders Goldwing Forums
post #11 of 14 (permalink) Old 06-25-2019, 08:54 AM
Originally Posted by Nyme View Post
great thanks for that. Instructions all seem to suggest disconnecting hose and holding above shock so dont lose oil and let air in, is there any particular reason why people dont just clamp the hose prior to disconnecting it as i would for brake caliper?
If you put the adjustment down to 0 before disconnecting the hose you won't lose any oil.
post #12 of 14 (permalink) Old 06-26-2019, 04:33 AM Thread Starter
ok thanks
Nyme is offline
post #13 of 14 (permalink) Old 06-27-2019, 07:42 AM Thread Starter
having done top off and tested, it loads much, the ride is better, but i still need to run at near 25 to get decent feel from rear end and not get jolted by all the road imperfections.
I believe you said used shocks up to 2018 will fit this? I have seen 2018 complete units on ebay from trike converters, that i would need to ship in to uk. before i do that, Can you or anyone confirm, do they straight replace? will i need to do any mods to swap over and will there be any difference in usage if i hook up the the preload switches?
Thanks
Nyme is offline
post #14 of 14 (permalink) Old 06-27-2019, 11:47 AM
Thanks
I don't think 2018s will fit but up through 2017 will, no difference in the connections.
